04-18-2015, 18:17 | #1 (permalink) |
No Life Poster Join Date: Mar 2014 Location: Kfe~Labs Co.- Age: 52
Member: 2140790 Status: Offline Sonork: 100.1679059 Thanks Meter: 212 | SM-G710 Unlock / repair Im3i (How To) I looking for info how ti unlock this set / repair imei.- here log. Por favor espere, entrando en "MODO TEST" ... Entrada en "MODO TEST": OK Nombre del modelo: SM-G710 Versión de SW: G710XXUANB4 N/S del teléfono: RV1F527NRN Por favor, primero resetee EFS Configuración de código MSL: Fallida ! Tiempo total utilizado: 14.4 s. When the phone is in download mode, say time out port not found. (check phone in Download mode) What can i do? the cable conect ok, This log is read with Cable C330 Thanks in advance aUTo |
04-19-2015, 02:24 | #2 (permalink) |
No Life Poster Join Date: May 2013 Location: Far From Home..:(
Member: 1948608 Status: Offline Thanks Meter: 1,744 | Let it Download Mode- Connect with Usb cable- select Correct Port According to D/M and reset Default EFS.. now connect with Urt by ON condition - select SPT port (Which port connecting spt box)select Superimei - tick both repair imei and unlock...usb Debbuging Must b On and keep device settings according to SPT manual....if not connect with urt than do battry trick.! |
The Following 2 Users Say Thank You to -Mosin- For This Useful Post: |
04-20-2015, 06:37 | #4 (permalink) |
Member: 1948608 Status: Offline Thanks Meter: 1,744 | Try 1 by 1 All Super imei And check Cert.status... if not gating cert.pass, than you have to wait for next update. may b spt will add more superimei.....! |
The Following User Says Thank You to -Mosin- For This Useful Post: |
04-20-2015, 17:04 | #5 (permalink) | |
Member: 2140790 Status: Offline Sonork: 100.1679059 Thanks Meter: 212 | sm-g710 Quote:
Thanks for support me.- Is done.- Best Regard aUTo | |
04-20-2015, 18:50 | #7 (permalink) |
No Life Poster Join Date: Jun 2009 Location: SouthAmericaUnlockers Age: 52
Member: 1057178 Status: Offline Sonork: Kfe~Labs Co.- Thanks Meter: 568 | full wipe/reset efs Copy last Upgrade SPT (b) (for super Imei popup) tick Imei and unlock press Factory mode.- The Phone loop many times, just wait.. all is ok.- If the signal bar is bad. make wipe full data manually More Super Imei for Bulk Works please.- Best Regards PolaCo ~ KfeLab Last edited by el-polaco; 04-20-2015 at 18:51. Reason: FOR TIME OUT PORT - USE TRICK BATTERY |
04-21-2015, 13:06 | #8 (permalink) |
No Life Poster Join Date: Apr 2005 Location: America
Member: 138781 Status: Offline Thanks Meter: 850 | full wipe/reset efs Copy last Upgrade SPT (b) (for super Imei popup) tick Imei and unlock press Factory mode.- (use cable uart/RJ45) and digit *#0808# select DM+MODEM+ADB The Phone loop many times, just wait.. all is ok.- If the signal bar is bad. make wipe full data manually If the cell have this lock, use chimeratool for factory UNLOCK Tito |
The Following User Says Thank You to cellcarcol For This Useful Post: |
04-21-2015, 19:31 | #9 (permalink) | |
Member: 2140790 Status: Offline Sonork: 100.1679059 Thanks Meter: 212 | Quote:
If the sm-g710 still with Cert Fail, write back qcn file enjoy! Best Regards aUTo | |
