01-04-2014, 15:02 | #16 (permalink) |
No Life Poster Join Date: Jan 2010 Location: iraq
Member: 1215266 Status: Offline Thanks Meter: 129 | Please Wait Enter Test Mode ... Enter Test Mode OK! Product ID: Unknown Not Support Current Hardware ! Please Use *#0808# Set USB Settings to DM + MODEM + ADB Total Time: 9.89 s |
01-06-2014, 12:11 | #18 (permalink) |
Freak Poster Join Date: Jan 2004 Location: Tirupati-India Age: 49
Member: 48156 Status: Offline Thanks Meter: 127 | hi AFTER UNLOCK NO NETWORK (NETWORKM HOT REGISTER) SPT TEAM DONT SLEEP GIVE SOME UPDATE NO OFF PHONE NOT WORKING Step 1 connect phone in download mode step 2 choose sm-n9005 in spt box step 3 click reset default efs step 4 write super imei step 5 enjoy hit thankx AFTER THIS METHERD NOT WORKING fake solution .............. Give good solution |
02-10-2014, 15:36 | #19 (permalink) |
Freak Poster Join Date: Nov 2007 Location: egypt Age: 37
Member: 625817 Status: Offline Sonork: 1592120 Thanks Meter: 32 | its worked again thnks team its work 1- reset efs 2-wirte super imei with unlock 3-write same super imei with untick unlock 4-chose n900w8 5-tick repair 3g a5- dial *#7284# and choose UART -> MODEM b5- dial *#0808# and chose dm+modem+adb c5-choose usb port then tick repair 3g this seloution worked with me |
The Following 2 Users Say Thank You to syrmic For This Useful Post: |
02-13-2014, 07:41 | #21 (permalink) |
Junior Member Join Date: Sep 2007
Member: 579609 Status: Offline Thanks Meter: 0 | final solutionn n9005 its worked again thnks team its work 1- reset efs 2-wirte super imei with unlock 3-write same super imei with untick unlock 4-chose n900w8 5-tick repair 3g a5- dial *#7284# and choose UART -> MODEM b5- dial *#0808# and chose dm+modem+adb c5-choose usb port then tick repair 3g this seloution worked with me thanks spt team |
03-13-2014, 09:57 | #24 (permalink) |
Freak Poster Join Date: Sep 2004 Location: Rabat Age: 54
Member: 80858 Status: Offline Sonork: 100.1601506 Thanks Meter: 8 | n 9005 not work for me 1- select n9005 reset efs by usb in download mood 2- unlock , repair super imei by com 3- select n900w8 repair 3g network by com |
04-25-2014, 09:12 | #26 (permalink) |
Junior Member Join Date: Apr 2014
Member: 2173849 Status: Offline Thanks Meter: 0 | i have note 3 sm n9005 with two different imei and i am from india .My note 3 is only working in 3g network whenever i am in 2g network its shows emeregency calls only very frustated what to do because i mostly be in 2g networks please help me to solve the problem.I m using this phone in India and have different IMEI when i dial *#06# its shows different IMEI number then the IMEI number written on the under the battery . Please help permanent solution or its having no solution tel me thanks in advance |
04-25-2014, 09:28 | #27 (permalink) | |
Member: 2173849 Status: Offline Thanks Meter: 0 | need urgent help regarding n 9005 Quote:
Please help permanent solution or its having no solution tel me thanks in advance will the above solution work for me too | |
