08-06-2014, 18:54 | #1 (permalink) |
No Life Poster Join Date: Sep 2007 Location: Gizah/Egypt Age: 33
Member: 594436 Status: Offline Sonork: 100.1657777 Thanks Meter: 952 | SM-N9005 .. Unlocking Problem i need help unlocking N9005 .. according to the guides i have to do 3 steps .. 1-RESET EFS .. [USB] 2-SUPER IMEI .. [UART] 3-REPAIR 3G NETWORK .. [USB] i'm stuck in the 2nd step .. i can't connect the phone with UART cable .. Please Wait Enter Test Mode ... Timeout ! Total Time: 15.75 s before RESET EFS i was able to change UART Settings by *#7284# .. but after RESET EFS .. that code do nothing .. there is no settings appears .. i tried to wipe the phone .. but still same .. the code do nothing .. and the UART cable isn't damaged .. it's working good .. i just tried it with another phone .. now i have SM-N9005 with 4.4.2 .. NO IMEI [after EFS reset] .. so, i need help connecting the phone via UART .. thx in advance. |
08-07-2014, 15:31 | #2 (permalink) |
No Life Poster Join Date: Apr 2013 Location: Calgary
Member: 1918024 Status: Offline Sonork: 100.1638888 Thanks Meter: 45 | when you get time out error 1. don't unplung the phone, and Uart cable, make sure the connection is good. 2. restart the phone 3. after the phone restart, wait a moment. Do not run the program right away. dial *#06* make sure the phone is responding 4. make sure to select correct comport (get the info from device manager) 5. then run factory mode 6. if still time out then change to another USB port or Uart cable redo it. |
08-09-2014, 17:19 | #3 (permalink) | |
No Life Poster Join Date: May 2009 Location: android efs
Member: 1042104 Status: Offline Sonork: 100.1609232 Thanks Meter: 216 | Quote:
try with octopus bro my tested ........ | |
