05-14-2015, 19:42 | #3 (permalink) |
No Life Poster Join Date: May 2013 Location: Far From Home..:(
Member: 1948608 Status: Offline Thanks Meter: 1,744 | Downlaod firmware, and change Extension to rar and extract it, now open odin and click on CP and choss modem.bin file from firmware and flash it. If baseband still unknown then you have to reset efs to default, then write superimei or imei cert file. |
The Following User Says Thank You to -Mosin- For This Useful Post: |
06-27-2015, 12:42 | #9 (permalink) |
No Life Poster Join Date: Oct 2006 Location: USA
Member: 362515 Status: Offline Sonork: 100.1590585 Thanks Meter: 160 | |
06-27-2015, 13:39 | #10 (permalink) | |
Member: 362515 Status: Offline Sonork: 100.1590585 Thanks Meter: 160 | Quote: it will not repair imei null..its for root at&t note4. if u could root by this method, u can wipe efs with third party software tool and eligible for write certificate file that which will grant imei and network back.. try yourself and post the result here.. am not tested.. just sharing for help. credits to XDA forums.. | |
06-28-2015, 10:11 | #11 (permalink) | |
Freak Poster Join Date: Apr 2015 Age: 33
Member: 2372105 Status: Offline Sonork: 100.1667845 Thanks Meter: 61 | Quote:
it never works .. I flash all baseband modem >> >> irreparably null imei .....: Đảo mắt: | |
06-30-2015, 13:27 | #13 (permalink) |
No Life Poster Join Date: Sep 2014 Age: 46
Member: 2260435 Status: Offline Thanks Meter: 118 | Here is Wipe EFS NO ROOT: http://*********/dNCfKUE4-9w This method work on kitkat, if your running lollipop you must downgrade first (I prefer flash to stock kitkat anyway). If your phone is not hardware problem the imei change to 00/1 or something. Then you can imei repair. Enviado desde mi SM-N910T mediante Tapatalk |
