10-10-2014, 13:42 | #16 (permalink) | |
Freak Poster Join Date: Mar 2011 Location: Dallas
Member: 1543792 Status: Offline Sonork: N/A Thanks Meter: 12 | Quote:
I bet your Product ID is all zeros. if it is I think your FTDI chip is no longer any good. | |
10-10-2014, 14:56 | #17 (permalink) | |
You can use any kind of box/cables with SPT software. Just connect yourr box.cable, run SPT and select COM port of your other box. | |
10-10-2014, 19:14 | #18 (permalink) | |
Freak Poster Join Date: Dec 2012
Member: 1851293 Status: Offline Thanks Meter: 19 | Quote:
10-10-2014, 19:43 | #19 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Try to install D2XX drivers for your "Other Devices" -> "SPT BOX" device before use MProg. D2XX Direct Drivers |
10-10-2014, 23:51 | #20 (permalink) | |
10-11-2014, 01:30 | #21 (permalink) | |
If you have the same issue with one more box this means that its a problem with Win. Im not sure but it may be result of automatic updates. I can not find another reason. What to do: try to install not latest but more old FTDI drivers. Lets see results. | |
10-11-2014, 06:12 | #22 (permalink) | |
The solution Mprog works but in order for the program to recognize the box I installed the drivers as USB serial port and select FTDI Manufacture, then still the program would not find it on scan, but when press program, it does work. I got it back. I also did the same with z3 box and it works too but the only problem is share COM port # so I can only have 1 connected. | |
10-11-2014, 09:52 | #23 (permalink) | |
Program your boxes FTDI eeprom with Infinity .ept file (see link to Infinity support area in my previous post). After that I think you will be able to connect both boxes at the same time and you will get different COM port numbers. Also you can program one as Infinity and 2nd one leave as Default. Waiting for your results. | |
10-13-2014, 01:54 | #24 (permalink) | |
Freak Poster Join Date: Aug 2007
Member: 558861 Status: Offline Thanks Meter: 26 | Quote:
i have same problem any help plz ? | |
10-13-2014, 10:57 | #27 (permalink) | |
10-13-2014, 11:08 | #29 (permalink) | |
1. latest FTDI VCP drivers is here: Virtual COM Port Drivers How to re-install FTDI drivers in case of any problems or conflicts with another boxes: 1. disconnect box from PC 2. uninstall FTDI drivers: C:\Windows\system32\ftdiunin.exe 3. reboot PC 4. connect box to PC and install FTDI drivers from Infintiy-Box package How to re-program box FTDI eeprom: 1. download "MProg" software: FTDI Utilities 2. download and install latest D2XX drivers: D2XX Direct Drivers 3. program FTDI with FT232R_Infinity.ept 4. install FTDI VCP drivers: Virtual COM Port Drivers How to reset box FTDI eeprom to default values: 1. download "MProg" software: FTDI Utilities 2. download and install latest D2XX drivers: D2XX Direct Drivers 3. erase FTDI eeprom content | |
