10-13-2014, 11:49 | #32 (permalink) | |
I have posted very detailed instruction earlier and all that you can reply "please give me instruction". I do not see any reason to explain more if you even can not say what is the problem exactly. If you need more assistance - you can contact to your Reseller (man who have got money from you for box) or you can contact to supporters who is listed in SPT forum as "Product supporters". | |
10-14-2014, 13:18 | #36 (permalink) | |
You have an instruction already but you have ignored it by unknown reason so why continue to ask for a help without giving any your own results ? | |
10-15-2014, 11:44 | #38 (permalink) | |
What is the results ? | |
10-17-2014, 08:31 | #39 (permalink) |
Freak Poster Join Date: Mar 2011 Location: Dallas
Member: 1543792 Status: Offline Sonork: N/A Thanks Meter: 12 | When Mprog doesnt connect you have an incorrect driver installed. You must uninstall all the box drivers and force install the FTDI driver as a usb to serial convertor and then Mprog will detect it. |
10-20-2014, 00:28 | #40 (permalink) | |
Freak Poster Join Date: Dec 2012
Member: 1851293 Status: Offline Thanks Meter: 19 | Quote:
10-20-2014, 00:51 | #41 (permalink) | |
Member: 1543792 Status: Offline Sonork: N/A Thanks Meter: 12 | Quote:
Hey did you use the default.ept and modify or did you pull one from a working SPT box? Same question as above for the Z3x? Also the SPT has done the same problem as before so I reprogram and it works for a while is there a more permanent solution? | |
10-20-2014, 03:09 | #43 (permalink) |
Member: 1851293 Status: Offline Thanks Meter: 19 | I went thru the same thing every time that I turn off the computer or unplug/plug back the drivers were gone again,I switched USB ports and that seem to worked, luckily my computer has a bunch of USBs. Im using the boxes on USB 3.0 and that fixed it, the boxes are recognized as before but without the names. I used default settings for Z3x. |
10-20-2014, 03:10 | #44 (permalink) |
10-20-2014, 03:15 | #45 (permalink) |
