10-08-2014, 01:32 | #1 (permalink) |
Freak Poster Join Date: Dec 2012
Member: 1851293 Status: Offline Thanks Meter: 19 | SPT Box NOT working[ANSWERED] |
10-08-2014, 04:20 | #2 (permalink) | |
No Life Poster Join Date: Sep 2013 Location: Kotla Arab Ali Khan(PAK)
Member: 2016954 Status: Offline Thanks Meter: 345 | Quote:
download new setup insatall agin ther is no bug | |
10-08-2014, 18:40 | #6 (permalink) |
No Life Poster Join Date: May 2006 Location: XpErTs GsM ® Age: 40
Member: 272796 Status: Offline Sonork: 1603232 Thanks Meter: 411 | All Drivers Are Located in { C:\Program Files\SPT\Drivers } Folder. If Drivers is not Install may Be you have to Reinstall Your Windows.. All Ways Use Latest SPT Software.. Keep Windows Clean From Virus and Driver Problems. Check Your Box on other PC.. |
10-09-2014, 14:50 | #8 (permalink) | |
Member: 1851293 Status: Offline Thanks Meter: 19 | Quote:
Try using a dff box to install drivers same results. KEEP IN MIND, this is NOT a new box, I've been using it for at least 6 months, DRIVERS ARE in the same place NO CHANGES WERE MADE to either Windows/drivers/computer files. I do work in computers and I'm not a noob per-say so I know how to install drivers, the problem is the box itself. I connected the BOX 2 days ago to the same computer I use everyday and did not work, just stop working, tried on a different computer same results, reinstalling windows DOES NOT WORK. HAVE 4 COMPUTERS 3 with windows 7, 1 with windows XP, SAME RESULTS. There is something wrong with the configuration inside the box, it might had reset itself i do not know. | |
10-09-2014, 14:56 | #9 (permalink) |
Member: 1851293 Status: Offline Thanks Meter: 19 | Thats why I'm trying to get help now, I do NOT want to buy another box if the same problem keeps happening. so SPT people any solutions ideas, besides buying a new box??????? |
10-09-2014, 14:59 | #11 (permalink) | |
10-10-2014, 00:01 | #12 (permalink) | |
10-10-2014, 10:08 | #13 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Possible reason: 1. Box hardware fault 2. Box internal config (eeprom data) fault How to fix: 1. Open your box and check its PCB. Replace damaged parts if need 2. Here is files and instruction: server1 download area Yes, after re-program you will get COM port with name "Infinity-Box" or just "FTDI" but actually its not so important for phone repair process |
10-10-2014, 11:36 | #14 (permalink) |
Freak Poster Join Date: Mar 2011 Location: Dallas
Member: 1543792 Status: Offline Sonork: N/A Thanks Meter: 12 | I just had the same problem and I cannot install any driver and when it does allow install the computer blue screens. I think its a crappy or knock off ftdi chip. I ordered a new FT232RL and will replace and post results. |
10-10-2014, 11:38 | #15 (permalink) |
Member: 1543792 Status: Offline Sonork: N/A Thanks Meter: 12 | I do have a question.. Does anyone with the spt also have the SELG box. If so can you disassemble and compare components to the spt. SELG Fusion Box SE Tool Pack w/o smart-card (10 cables) - GsmServer Maybe I buy some of these if they are the same or similar so when spt craps out again I can just use this other interface and not have to wait on a replacement part. |
