Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > SPT BOX
Old 04-29-2014, 10:55   #46 (permalink)
gsm_'s Avatar
Member: 991620
Thanks Meter: 428
same problam iam use activator spt folder
Old 04-29-2014, 12:10   #47 (permalink)
gsm_'s Avatar
Member: 991620
Thanks Meter: 428
5days my problam not solved infinity team
Old 04-29-2014, 22:17   #48 (permalink)
Member: 1043909
Thanks Meter: 45,590
Originally Posted by gsm_ View Post
how to solve this errors
help me spt team
If you have Infinity-Box or BEST or CDMA-Tool - contact to [email protected]
The Following User Says Thank You to YellowBoss For This Useful Post:
Old 04-29-2014, 22:18   #49 (permalink)
Member: 1043909
Do not lie please !
If you want to get your problem solved - just contact to [email protected]
Old 04-29-2014, 22:18   #50 (permalink)
Member: 1043909
If you have Main Infinity-Box or BEST or CDMA-Tool - contact to [email protected]
Old 04-29-2014, 22:19   #51 (permalink)
Member: 1043909
Originally Posted by ihsan.khan.gsm View Post
how money for activetion any body know
Hello,
Here is Prices: Infinity-Box - Price-list
Old 06-26-2014, 15:54   #52 (permalink)
hassan1975's Avatar
Member: 28819
Thanks Meter: 220
hello
i cant go in support for downlode flash
pls reset my acccount
spt
searching dongle...
dongle found
firmware version: 0004
SPT-Box serial number (S/N): 00002D294CB8DE4D (11561)
dongle hardware serial: 000ADBF9FF021982
==> SPT-Box S/N: 00002D294CB8DE4D (11561)
thx
Old 06-27-2014, 13:54   #53 (permalink)
Member: 148515
Thanks Meter: 10,968
Originally Posted by hassan1975 View Post
hello
spt
searching dongle...
dongle found
thx
Dear Friend,
This thread name is SPT-Box Software Activations for Infinity-Box products but you have SPT-Box but not Activation for Infinity.
You must contact to your reseller or to spt support directly.
Old 07-29-2014, 10:10   #54 (permalink)
uttam's Avatar
Member: 223135
Sonork: 100.1592685
Thanks Meter: 176
Pls Help Me SIr
Cant Active Dongle
2014.07.29 08:07:39 103.250.165.124 : register : serial [00003BE16E******, 1****] should be activated via reseller !
Wrong reply from server: 2014.07.29 08:07:39 103.250.165.124 : register : serial [00003BE16E5*****, 1****] should be activated via reseller !
Contact to [email protected]
Failed: 00003BE16E5*****
Uttam
Old 07-30-2014, 13:20   #55 (permalink)
Member: 1043909
Originally Posted by uttam View Post
Cant Active Dongle
Uttam
Dear Friend,
Old 08-10-2014, 12:19   #56 (permalink)
notgood's Avatar
Member: 355635
Thanks Meter: 53
Originally Posted by YellowBoss View Post
Hello,
There is a bug in SPT software installer. SPT programmers must change destination folder in installer or change user.ini file location to avoid this kind of user's problems.
What to do now:
Login to your PC as Administrator and copy user.ini to folder with SPT software.
how to login as Administrator ini win8.1? can you guide step by step how its work? thanks in advance
Old 08-10-2014, 12:33   #57 (permalink)
notgood's Avatar
Member: 355635
Thanks Meter: 53
i already did it like you said, run pc as administrator in my win8.1 and copy user.ini, but spt program stil cant find my infinitybox comport?
how i solve this problem? thanks ini advance
Old 08-11-2014, 10:38   #58 (permalink)
Member: 1043909
Hello,
So, you can run SPT software but COM port is not found. Right ?
If yes: you must install FTDI VCP drivers: http://www.ftdichip.com/Drivers/VCP.htm
After that you will see COM port in your PC Device Manager and in software.
Old 08-13-2014, 07:58   #59 (permalink)
notgood's Avatar
Member: 355635
Thanks Meter: 53
Hello,
If yes: you must install FTDI VCP drivers: Virtual COM Port Drivers
am already have driver you said n already instal it, i can see com port infinity, n my infinitybox can run n work good, but if i run spt program, then i select com port. in spt program i only see auto comport, but cant see infinity comport as the base
Old 08-13-2014, 21:27   #60 (permalink)
Member: 148515
Hello,
Its quite strange that you can not select COM port in SPT software.
Please post here SPT software screenshot.
Also, do you have any other box/cables ?
Page generated in 0.35254 seconds with 8 queries
