Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > SPT BOX
Old 01-12-2012, 12:41   #16 (permalink)
wgmmmx1's Avatar
Member: 1139057
Sonork: 100.109924
I9100, T989, T989D Unlock / IMEI Procedure !!
T989-T989D-I9100-N7000 Unlock,Imei Procedure:
1) Put Phone Download Mode
2) Connect Phone to Usb
3) Press RESET DEFAULT EFS
4) After Progress Done Power On Phone
5) Connect Cable
6) Mark Imei and Unlock
7) Press Factory Mode
If not working in last update or get timeout just use version 13.3.6
All do with just USB cable !! !! !!
Some new I9100 need use from step 5 uart box S7070 cable !! !! !!
The Following 8 Users Say Thank You to wgmmmx1 For This Useful Post:
Old 01-12-2012, 12:45   #17 (permalink)
wgmmmx1's Avatar
Member: 1139057
Sonork: 100.109924
I727 Unlock / IMEI Instruction !! !!
I727 Unlock,Imei Procedure:
*Power On Phone
Do next:
1. Application -> Settings -> Applications -> Development -> USB debugging
2. Enter *#7284# And Set USB to Modem
3. Enter *#9090# And Choise UART <--- you use box cable mean UART need select
* Connect Box Cable S7070/C3300K
* Mark Imei and write orginal(or not depent that you want change or not) and Unlock
* Press Factory Mode
The Following 4 Users Say Thank You to wgmmmx1 For This Useful Post:
Old 02-24-2012, 12:14   #18 (permalink)
wgmmmx1's Avatar
Member: 1139057
Sonork: 100.109924
I9020, I9023 and other I90xx repair EFS/Unlock/IMEI
Procedure of Direct EFS Repair-Imei-Unlock:
* Phone Should be roooted if os version high then 2.2.1
* For Root Operation check http://forum.xda-developers.com
* After root Open in settings of phone usb debug
* Connect Phone to Usb Then Press Re-Scan button and select adb port number
* Mark Repair imei - unlock - reset phone
* Press Spt mode
* After Progress done phone will restart
* Disconnect cable after restart then re-connect
* Select Adb Port then mark unlock or imei which u want press factory mode.
* For read code should lockcodetable file on your pc under lockcodetables folder
* Just need press factory mode without mark anything its will read unlock code
* I9023 Will give timeout in factory mode its need repower phone in recovery mode then make factory reset / wipe data
The Following 2 Users Say Thank You to wgmmmx1 For This Useful Post:
Old 02-29-2012, 19:19   #19 (permalink)
wgmmmx1's Avatar
Member: 1139057
Sonork: 100.109924
B2710 unlock / imei procedure !! !!
B2710 unlock / imei procedure !! WORKING ON ANY FIRMWARE VERSION !! !! !!
1. Check in phone firmware version by *#1234#
2. Download from sptbox support the same firmware version that is in phone or higher(most higher now is B2710XXKJ1) and unpack somewhere
3. Select Reset Msl box and in bootfiles box select any file from BOOTFILES directory
4. Connect phone in download mode(to enter download mode press: vol down + 9 + power on, on screen you will see phone with arrow) to usb cable
5. Press Write button
6. After bootfiles write and phone restart again turn phone in download mode and connect to usb cable
7. Uncheck RESET MSL and press Write button again, After files write and phone restart disconnect from usb cable and wait to fully turn on.
8. When phone full on writeon keyboard *#782872# and live phone on this screen
9. Connect usb cable and nothing press on phone live like is.
10. Install Qualcomm drivers from spt directory(modem, diagnostic port etc)
11. Press RE-SCAN to software select correct port
12. Select IMEI and write in box orginal one from label(or any other like you need), select unlock and press factory mode
Wait 30-40 secound and phone will be unlocked and imei changed to selected.
That all.
END
Old 03-07-2012, 16:01   #20 (permalink)
wgmmmx1's Avatar
Member: 1139057
Sonork: 100.109924
Unlock / IMEI procedure T959v, T959p, I997
Procedure Of T959v - T959w - T959P - I997 Unlock / Imei
* Put Phone Download Mode
* Connect Usb Cable
* Select Modem Port
* Fill İmei Area(imei from label or other), check UNLOCK, RESET
* Press Spt Mode
If will be still problem with comunication use UART cable just select I9003 write imei from label, check unlock and press Factory Mode.
Old 03-22-2012, 10:15   #21 (permalink)
wgmmmx1's Avatar
Member: 1139057
Sonork: 100.109924
I9250 unlock procedure !!
Like in topic unlock procedure on picture with help one from spt users.
And instruction for all other that can't understand picture.
I9250 Unlock/Imei Procedure:
* First Download At Support I9250XX_test.rar
* Flash To phone for port mapping
* Put Phone Download Mode Press RESET DEFAULT EFS
* After That Connect phone uart cable then mark unlock and repair imei
* Press Factory mode.
The Following 14 Users Say Thank You to wgmmmx1 For This Useful Post:
Old 06-02-2012, 17:59   #22 (permalink)
Member: 455745
sc-03d docomo unlock procedure step by step
unlock procedure:
Turn on usb debugging mode in phone setting
Enter *#9090# And Choise USB Diag
Restart phone by turn off/on it
Select Modem Port in spt software
tick unlock and press Factory Mode button.
Old 06-12-2012, 19:30   #23 (permalink)
wgmmmx1's Avatar
Member: 1139057
Sonork: 100.109924
I9300 Galaxy S 3 unlock procedure !!
NEW Procedure OF N7100/I9300/I9308 Following:
* Turn usb debug in phone setting
* First Make Root Phone
* Mark Unlock(if just want unlock) Press SPT MODE
* If want imei should mark repair imei and unlock together
* Then Factory Mode.
Factory mode use box/uart cable !! !! !!
NEW INSTRUCTION WORK ONLY WITH SPT 15.0.5B or higher !! !! !!
The Following 6 Users Say Thank You to wgmmmx1 For This Useful Post:
Old 08-27-2012, 11:27   #24 (permalink)
wgmmmx1's Avatar
Member: 1139057
Sonork: 100.109924
P3100 and P5100 unlock / imei instruction
Procedure Of P3100 and P5100 IMEI And UNLOCK Following:
1. Turn usb debug in phone setting
2. Root phone manualy
some step by step instruction are in XDA forum or file needed are in our support
3. Connect Phone Powered On To USB CABLE
4. Select unlock or imei or both and Press Spt Mode.
When end do next:
5. Select unlock or imei or both and press Factory Mode.
Old 11-03-2012, 12:24   #25 (permalink)
wgmmmx1's Avatar
Member: 1139057
Sonork: 100.109924
I9210 unlock / imei instruction
Procedure of I9210 Imei/Unlock :
* Connect Phone IN Download Mode Press Reset Default EFS
* Then Repair SN
* Mark Repair imei and unlock then press Factory mode.
Old 02-05-2013, 08:41   #26 (permalink)
79mobile's Avatar
Member: 272091
Sonork: 100:114011
Manual for unlocking SGH-i747
Before you need to unlocking this model just flashing file I747UCALEM_Patch.rar Download from support area.
Then falshed poweron phone pess key *#7284# > pda > on dm+modem+adb and unlock ok.
Old 03-07-2013, 10:07   #27 (permalink)
wgmmmx1's Avatar
Member: 1139057
Sonork: 100.109924
Unlock/IMEI tutorial for S7562 / S7562i / S7568
Tutorial For S7562/S7562I/S7568 Following :
* Connect Phone To usb with Usb debug active
* Press Spt Mode and Wait till Phone Restart
* After Phone restart again do SPT MODE
* Then Factory Mode
Old 03-07-2013, 10:09   #28 (permalink)
wgmmmx1's Avatar
Member: 1139057
Sonork: 100.109924
Unlock / imei instruction for I9082 and other new models
Tutorial For I9082 and other new phones added following:
* Download Patch file from support area.
*Flash to phone with patch file.
* Then Do Factory Mode
Old 03-22-2013, 21:34   #29 (permalink)
wgmmmx1's Avatar
Member: 1139057
Sonork: 100.109924
Procedure for Unlock/Imei i9305, N7105 other new
Phone must be ROOTED before start !! !! !!
Procedure of new Phone Unlock/Imei(i9305,N7105 etc)
Enter in phone
*#7284# and choose UART -> MODEM
Enter *#9090# And Choise DM over UART
* First Put Phone Download mode then select modem port
* Press Reset Default Efs.
* After Phone Restart Connect to uart cable
* Select box Port then Do Factory mode
Unlock procedure for I317-I317M
*After phone restart select unlock/imei and press spt mode
*After phone restart select unlock/imei and press factory mode
That all.
If on factory mode you will got timeout just use uart/box cable C3300 with 525k or 530k ressistor inside.
The Following User Says Thank You to wgmmmx1 For This Useful Post:
Old 05-14-2013, 02:38   #30 (permalink)
Member: 1757495
Wink Galaxy Y s5360T unlock solution
this is a simple guide for those pp tried to unlock s5360T
Firstly flash s5360T patch which can download from support area
Then tick imei repair and unlock, do factory mode
After that, you sould see succesfully unlocked.
Logs might be shows blablabla then NCK 00000000
try to put a different simcard into the phone, a windows gonna pop up, ask you to type network unlock code. you just need to type NCK code in, such as 00000000
@ all SPTbox users.............here please -= vintel =- SPT BOX 14 11-22-2008 02:32
Typhoon user guide / installation guide cellular_net Typhoon Dongle 16 02-02-2008 20:40
V60 user guide neeeded billgate P2k Series 0 06-12-2002 15:54
Motorola Timeport 260 Users Guide (en,ro) MARIUSI P2k Series 1 04-10-2002 07:40
Motorola Timeport 260 Users Guide MARIUSI P2k Series 1 04-10-2002 06:43
Page generated in 0.58423 seconds with 12 queries
