09-03-2014, 06:47 | #32 (permalink) |
Junior Member Join Date: Jan 2011 Location: INDIA
Member: 1504393 Status: Offline Sonork: 1504393 Thanks Meter: 1 | piliz help me.. SM-G7102 Imei Repier dane on ne netwark sir pilizzz........... help me....... SM-G7102 Imei Repier dane on ne netwark and network repier done ................no network pilizzzzz........help me....... |
09-03-2014, 18:56 | #33 (permalink) |
No Life Poster Join Date: Apr 2006 Location: Pako new road,Nepal
Member: 257603 Status: Offline Sonork: 100.1605284 Thanks Meter: 147 | After writing super imei again select g7106 thereu can see 3g option active then repair in that all will be working fine. |
09-03-2014, 18:56 | #34 (permalink) | |
No Life Poster Join Date: May 2009 Location: android efs
Member: 1042104 Status: Offline Sonork: 100.1609232 Thanks Meter: 216 | Quote:
09-04-2014, 21:20 | #35 (permalink) |
Insane Poster Join Date: Sep 2013 Location: Syria, Idleb Age: 31
Member: 2019489 Status: Offline Thanks Meter: 57 | Wifi Issue I try this on 4 mobiles and succes just flash this file in PDA by ODIN 3 https://www.dropbox.com/s/kh11uw0tj2...E_EFS.tar?dl=0 |
09-07-2014, 19:15 | #36 (permalink) | |
No Life Poster Join Date: Jul 2006 Location: Comilla Age: 42
Member: 304260 Status: Offline Sonork: 100.1593127 Thanks Meter: 355 | Quote:
This is worked for Me..... This Solution Like SM-N9005 | |
09-11-2014, 09:16 | #38 (permalink) |
Member: 1042104 Status: Offline Sonork: 100.1609232 Thanks Meter: 216 | spt ver 18.1.8 sptcard1818 use and enjoy w.b.r just press thanks button Last edited by bod; 10-10-2014 at 15:47. Reason: Removed Email Add.. |
09-24-2014, 08:48 | #42 (permalink) |
Freak Poster Join Date: Jul 2010 Location: delhi(india) Age: 38
Member: 1343470 Status: Offline Thanks Meter: 64 | mr. rajakhank3 i wll give u some little information....... no need to do 1st step n 2nd step then ur all produse is ok.... step 3 select spt sm-g7102 and conect set with usb debuging on step 4 after conect sucsess fully doing reset efs default with modem port step 5 after efs default select spt port and select super imei master and slave tab then do factory mode ..... now imei change sucsessfully network repair method..... dail *#0808# then Select "DM+Modem+ADB now select in spt tab sm-g7106 and select samsung port and repair 3g network now sucsessfully repair network enjoy all forum members ....if you like my post then press thanks w.b.r extreamly thxx to mr.. rajakhank3 Last edited by bod; 10-10-2014 at 15:31. Reason: Removed Email Add.. |
The Following 2 Users Say Thank You to GTECH MOBILE For This Useful Post: |
09-29-2014, 08:55 | #43 (permalink) | |
Freak Poster Join Date: Sep 2006 Location: KZ
Member: 349343 Status: Offline Thanks Meter: 32 | Quote:
*#0011# network: blocked imei certi: (M)fail, (S)fail | |
