Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > SPT BOX
Old 08-31-2014, 12:45   #31 (permalink)
Member: 2186143
Thanks Meter: 5
g7102 3g network not work
After repair imei SM-G7102 3g Network not working
Old 09-03-2014, 06:47   #32 (permalink)
Member: 1504393
Sonork: 1504393
piliz help me.. SM-G7102 Imei Repier dane on ne netwark
sir pilizzz...........
help me.......
and network repier done ................no network pilizzzzz........help me.......
Old 09-03-2014, 18:56   #33 (permalink)
Member: 257603
Sonork: 100.1605284
Thanks Meter: 147
After writing super imei again select g7106 thereu can see 3g option active then repair in that all will be working fine.
Old 09-03-2014, 18:56   #34 (permalink)
rajakhank3's Avatar
Member: 1042104
Sonork: 100.1609232
Thanks Meter: 216
help me.......
post here full log .................
Old 09-04-2014, 21:20   #35 (permalink)
Member: 2019489
Thanks Meter: 57
Wifi Issue
I try this on 4 mobiles and succes
just flash this file in PDA by ODIN 3
https://www.dropbox.com/s/kh11uw0tj2...E_EFS.tar?dl=0
Old 09-07-2014, 19:15   #36 (permalink)
.:Towhid:.'s Avatar
Member: 304260
Sonork: 100.1593127
Thanks Meter: 355
Originally Posted by rajakhank3 View Post
here is the procudure step by step
step1 flash G7102XXUANC3_G7102ODDANC3_INS.zip this ver
step 2 after flash set do har reset with clear chache
step 3 select spt sm-g7102 and conect set with usb debuging on
step 4 after conect sucsess fully doing reset efs default with modem port
step 5 after efs default select spt port and select super imei master and slave tab then do factory mode .....
now imei change sucsessfully
network repair method.....
dail *#0808# then Select "DM+Modem+ADB
now select in spt tab sm-g7106 and select samsung port
and repair 3g network now sucsessfully repair network
enjoy all forum members ....if you like my post then press thanks
w.b.r
[email protected]
This is worked for Me..... This Solution Like SM-N9005
Old 09-10-2014, 05:27   #37 (permalink)
atinder_2006's Avatar
Member: 1809913
Thanks Meter: 35
What version of spt are you using?
Old 09-11-2014, 09:16   #38 (permalink)
rajakhank3's Avatar
Member: 1042104
Sonork: 100.1609232
Thanks Meter: 216
Originally Posted by atinder_2006 View Post
what version of spt are you using?
spt ver 18.1.8
sptcard1818
use and enjoy
w.b.r
just press thanks button
Old 09-11-2014, 22:00   #39 (permalink)
Member: 1491384
Thanks Meter: 2
I flash 4.4.2, i now have no network . Any solution? Downgrade not working.
Old 09-14-2014, 15:53   #40 (permalink)
Member: 1719042
Thanks Meter: 8
How to install the Russian language?
Old 09-19-2014, 18:38   #41 (permalink)
Member: 2253249
Thanks Meter: 29
brother g7102 imei done yes or no
yes
so explane prosiger
Old 09-24-2014, 08:48   #42 (permalink)
GTECH MOBILE's Avatar
Member: 1343470
Thanks Meter: 64
mr. rajakhank3 i wll give u some little information.......
no need to do 1st step n 2nd step then ur all produse is ok....
w.b.r
extreamly thxx to mr.. rajakhank3
The Following 2 Users Say Thank You to GTECH MOBILE For This Useful Post:
Old 09-29-2014, 08:55   #43 (permalink)
Member: 349343
Thanks Meter: 32
w.b.r
[email protected]
No network, 2 - g7102
*#0011# network: blocked
imei certi: (M)fail, (S)fail
Old 09-29-2014, 15:03   #44 (permalink)
Member: 797019
Thanks Meter: 25
also works in G7102T or only G7102?
Old 09-30-2014, 18:12   #45 (permalink)
rajakhank3's Avatar
Member: 1042104
Sonork: 100.1609232
Thanks Meter: 216
do not try just for 7102 solution
The Following User Says Thank You to rajakhank3 For This Useful Post:
Page generated in 0.38495 seconds with 8 queries
