08-03-2014, 17:43 | #1 (permalink) |
No Life Poster Join Date: May 2009 Location: android efs
Member: 1042104 Status: Offline Sonork: 100.1609232 Thanks Meter: 216 | step by step sucsess fully repair imei and network samsung grand2 sm-g7102 step1 flash G7102XXUANC3_G7102ODDANC3_INS.zip this ver step 2 after flash set do har reset with clear chache step 3 select spt sm-g7102 and conect set with usb debuging on step 4 after conect sucsess fully doing reset efs default with modem port step 5 after efs default select spt port and select super imei master and slave tab then do factory mode ..... now imei change sucsessfully network repair method..... dail *#0808# then Select "DM+Modem+ADB now select in spt tab sm-g7106 and select samsung port and repair 3g network now sucsessfully repair network enjoy all forum members ....if you like my post then press thanks w.b.r [email protected] |
The Following 16 Users Say Thank You to rajakhank3 For This Useful Post: |
08-04-2014, 10:46 | #4 (permalink) |
No Life Poster Join Date: Apr 2006 Location: Tunisia
Member: 261437 Status: Offline Sonork: no Thanks Meter: 922 | tested by my friend and g7102 it's ok 1-just To reset EFS choose G7107 2-To repair imei choose g7102 ( super imei ) |
The Following User Says Thank You to noure30 For This Useful Post: |
08-08-2014, 18:06 | #9 (permalink) |
Insane Poster Join Date: Aug 2014 Location: egypt
Member: 2232890 Status: Offline Thanks Meter: 9 | i have aproblem in last step this is the log Please Wait Enter Test Mode ... Enter Test Mode OK! Product ID: Unknown Please Use *#0808# Set USB Settings to DM + MODEM + ADB Total Time: 7.59 s |
The Following User Says Thank You to madoooz For This Useful Post: |
08-08-2014, 18:26 | #10 (permalink) | |
Member: 2232890 Status: Offline Thanks Meter: 9 | Quote:
Enter Test Mode OK! Product ID: M8626AAAAANAZM-1 Please Wait Repair 3G Network Data ... Repair Jobs Done. Total Time: 122.71 s but also no network any help | |
08-09-2014, 14:53 | #14 (permalink) | |
Member: 1042104 Status: Offline Sonork: 100.1609232 Thanks Meter: 216 | Quote:
Tested on Note3 SM-n900 and S4 i337M 1. Root your device first 2. Install root explorer.apk on phone 3. Open root explorer and go to efs folder(dont forget to mount as R/W) 4-Delete efs folder(try again if say error) 5-press power button to turn off 6-use repair imei or unlock | |
