08-15-2014, 16:59 | #17 (permalink) |
No Life Poster Join Date: May 2009 Location: android efs
Member: 1042104 Status: Offline Sonork: 100.1609232 Thanks Meter: 216 | all forum members note the point : if uart conection problem then hard reset with wipe chache and try with uart w.b.r [email protected] |
08-16-2014, 23:53 | #19 (permalink) |
Insane Poster Join Date: May 2014 Location: ******
Member: 2193576 Status: Offline Thanks Meter: 19 | hello .. I updated my grand 2 to 4.4.2. But I found slow net issues. Then I try to back to 4.3 jellybean. But I flash again by odin. But suddenly hang in updating. I remove battery. But I put battery now my phone not charge not going to on . I use many methods to make again download mode. But fail. I make jtag but fail no boot. Please give me any way to put back my grand 2 in normal position. Please help please |
08-19-2014, 08:54 | #22 (permalink) | |
Member: 1042104 Status: Offline Sonork: 100.1609232 Thanks Meter: 216 | Quote:
08-20-2014, 16:36 | #24 (permalink) | |
Tested on Note3 SM-n900 and S4 i337M 1. Root your device first 2. Install root explorer.apk on phone 3. Open root explorer and go to efs folder(dont forget to mount as R/W) 4-Delete efs folder(try again if say error) 5-press power button to turn off 6-use repair imei or unlock With other box(asansam not supported this model) | |
The Following User Says Thank You to rajakhank3 For This Useful Post: |
08-23-2014, 10:27 | #25 (permalink) | |
No Life Poster Join Date: Oct 2006
Member: 368546 Status: Offline Thanks Meter: 235 | Quote:
i have 100pc first 2 set dead with this file then i no further in another set dead with spt file and odin also aboot stuck and hang after that set dead | |
08-23-2014, 11:00 | #27 (permalink) | |
No Life Poster Join Date: Nov 2006 Location: (United States Of Islam) Age: 37
Member: 399832 Status: Offline Sonork: Faheem Anjum Thanks Meter: 24,310 | Quote:
infect on support area you will get 4.3 firmware , which is low then 4.4.2 and downgrading kill u r phone so Don,t try again | |
08-27-2014, 08:45 | #28 (permalink) |
Member: 1042104 Status: Offline Sonork: 100.1609232 Thanks Meter: 216 | note for all members this method is tested only 4.3 so be carefull if your set have 4.4.2 ver dont try flash 4.3 only try reset efs default an try with uart after har reset and then rpair network with 7106 |
08-30-2014, 07:26 | #29 (permalink) | |
No Life Poster Join Date: Jan 2009 Location: dil m hun
Member: 951882 Status: Offline Thanks Meter: 323 | Quote:
need plz flash file direct link or locastion G7102XXUANC3_G7102ODDANC3_INS.zip | |
