Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > SPT BOX
Old 09-30-2014, 18:13   #46 (permalink)
rajakhank3's Avatar
Member: 1042104
Sonork: 100.1609232
Thanks Meter: 209
Originally Posted by aanjo View Post
After repair imei SM-G7102 3g Network not working
if you have any problem contect me on yahoo or gmail
w.b.r
Old 09-30-2014, 18:14   #47 (permalink)
rajakhank3's Avatar
Member: 1042104
Sonork: 100.1609232
Thanks Meter: 209
Originally Posted by devr View Post
sir pilizzz...........
help me.......
SM-G7102 Imei Repier dane on ne netwark
and network repier done ................no network pilizzzzz........help me.......
contect me on yahoo or gmail i will solve your problem
w.b.r
Old 09-30-2014, 18:19   #48 (permalink)
rajakhank3's Avatar
Member: 1042104
Sonork: 100.1609232
Thanks Meter: 209
[QUOTE=shahrukhkhan904;10564838]Please Wait Enter Test Mode ...
Timeout !
Total Time: 16.31 s
am try reset default efs my phone not uart cable enter test mode plzz plzz help me
Faheem Anjum sir
just do hard reset and try with uart
best regard
w.b.r
Old 09-30-2014, 18:20   #49 (permalink)
rajakhank3's Avatar
Member: 1042104
Sonork: 100.1609232
Thanks Meter: 209
Originally Posted by mahtabansari View Post
brother g7102 imei done yes or no
yes
so explane prosiger
yes bro 1000% tested me and many users
if you have any problem then contact me on yahoo
The Following User Says Thank You to rajakhank3 For This Useful Post:
Old 10-02-2014, 10:53   #50 (permalink)
Member: 936228
Thanks Meter: 4
plz help i have wifi problem it work but does not connect any network
i do factory reset and wipe cach but the same
Old 10-02-2014, 11:50   #51 (permalink)
Member: 2045424
Originally Posted by en.osama View Post
I try this on 4 mobiles and succes
just flash this file in PDA by ODIN 3
https://www.dropbox.com/s/kh11uw0tj2...E_EFS.tar?dl=0
the link not working
Old 10-02-2014, 18:16   #52 (permalink)
rajakhank3's Avatar
Member: 1042104
Sonork: 100.1609232
Thanks Meter: 209
here is your link but this file not my tested ....use your own risk
SM-G7102ZKAMID_G7102DDUAML3_RF1F21N7JRE_EFS.tar - Download - 4shared
w.b.r
Old 10-05-2014, 08:24   #53 (permalink)
Member: 349343
Thanks Meter: 12
w.b.r
Bad efs file. I need efs tar file odin.
I need efs:
BACKUP:
1.Download terminal emulator from playstore
2. Open it and write: su
3. Allow root permission if asked
4. Write this: dd if=/dev/block/mmcblk0p11 of=/storage/extSdCard/efs.img bs=4096
5. Look at your ext sd for efs.img
The Following User Says Thank You to turboxxx For This Useful Post:
Old 10-07-2014, 00:40   #54 (permalink)
Member: 2019489
Thanks Meter: 57
Smile
I need efs:
BACKUP:
Here you are EFS file :
https://www.dropbox.com/s/j5welbmaf2...E_EFS.zip?dl=0
just unzip file and you will see efs.img and efs.md5 It is tested by me but use it on your risk, I wish it will help you
Alternative link:
https://www.mediafire.com/?128d1f1u7wy7cwi
The Following 2 Users Say Thank You to en.osama For This Useful Post:
Old 10-08-2014, 14:33   #55 (permalink)
Member: 1296661
Sonork: al_bahaa
Ok 4.3 natwwrk
no4.4.2 natwwerk
Old 10-09-2014, 15:50   #56 (permalink)
jorj_saha's Avatar
Member: 1649620
Sonork: 100.1603891
Thanks Meter: 177
repair 3g network ADD plz ......
Old 10-15-2014, 10:14   #57 (permalink)
Member: 1953341
repair imei g7102
hi bro i want to repair the network of g7102 in the
procedure i am all repair reflacher and write imei plz
give two super imei toujour when I put the sim card
network not recorded
Old 10-18-2014, 15:08   #58 (permalink)
Member: 1656305
Sonork: 100.1624503
Thanks Meter: 47
i cant repair mine... always timeout... im using 18.4.4... im gonna try other spt versions and post results...
Old 10-18-2014, 15:09   #59 (permalink)
Member: 1656305
Sonork: 100.1624503
Thanks Meter: 47
by the way, ive posted wifi solution months ago in spt section... here's the link
Wifi problem after unlock/default efs/imei? Solution here
Old 10-18-2014, 15:15   #60 (permalink)
Member: 1656305
Sonork: 100.1624503
Thanks Meter: 47
Originally Posted by noure30 View Post
tested by my friend and g7102 it's ok
1-just To reset EFS choose G7107
2-To repair imei choose g7102 ( super imei )
my friend, G7107 is not listed on 18.4.4.. so what version are you using?? thanks!!
Page generated in 0.37868 seconds with 7 queries
