Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > SPT BOX
Old 10-18-2014, 18:09   #61 (permalink)
Member: 2093517
Thanks Meter: 25
no 3g network.....gsm is ok ....i using super imei but no 3g and i wrrte flash from spt sup also no 3g?????? what do??
Old 10-18-2014, 18:18   #62 (permalink)
Member: 1719042
Thanks Meter: 8
This model it is necessary to choose: SM-G7106
Old 10-18-2014, 18:25   #63 (permalink)
Member: 2093517
Thanks Meter: 25
repair 3g with g7106 model but 3g not work
Old 10-19-2014, 04:25   #64 (permalink)
Member: 1719042
Thanks Meter: 8
read carefully if you want repair network then select sm-g7106 in spt tab (we are talking about the phone SM G7102 )
Old 10-19-2014, 08:14   #65 (permalink)
Member: 2093517
Thanks Meter: 25
i worked that but no 3g network
Old 10-20-2014, 21:03   #66 (permalink)
joshvimalraj88's Avatar
Member: 1625194
Thanks Meter: 30
Yesterday only I buy SPT BOX only for imei repair
Lets hope this work
And I will tell how it happened I just flashed with pit file
After that it shows imei /01 only this
Will my imei get back
Old 10-20-2014, 22:20   #67 (permalink)
Gambitv01's Avatar
Member: 1475064
Thanks Meter: 484
You around> or busy?
Originally Posted by valeraa1966 View Post
read carefully if you want repair network then select sm-g7106 in spt tab (we are talking about the phone sm g7102 )
you around> or busy?
Old 10-21-2014, 08:15   #68 (permalink)
Member: 1221964
Thanks Meter: 5
i flash with spt but not done sir
G7102XXUANB3.boot.spt
G7102XXUANB3.pda.spt
G7102ODDANA1.csc.spt
G7102DDUAML3.phone.spt
Detect Phone Connect ...
Connect Phone OK.
Get PIT for Mapping ...
Phone Init Failure !
Total Time: 5.96 s
Old 10-21-2014, 18:38   #69 (permalink)
Member: 1625194
Thanks Meter: 30
i update 4.4.2 and my imei shows only /01
i buy spt and restore efs with usb
and select spt port with uart cable but i get only time out eventhough i tried with hard reset and all uart cable no luck
Old 10-21-2014, 21:58   #70 (permalink)
Member: 1625194
Thanks Meter: 30
Can u please send me the link for 4.4.2 flas files for Spt
Old 10-22-2014, 08:48   #71 (permalink)
ashraf_bcs's Avatar
Member: 303373
Sonork: 100.1584377
Thanks Meter: 1,206
If after repair 3g by selecting G7106 still no 3g than contact with me by Sonork.
Old 10-22-2014, 09:28   #72 (permalink)
Member: 1625194
Thanks Meter: 30
I have spt box g7102 imei shows /01 as u said with usb using download mode I done restore efs
And after I select the spt port and and connect with rj45 cable but no use its get time out
Which cable should I have to use I tried many
Are tell me it should be connected in on condition or off conditions
Or some other please help me I am totally confused
Old 10-22-2014, 10:47   #73 (permalink)
ashraf_bcs's Avatar
Member: 303373
Sonork: 100.1584377
Thanks Meter: 1,206
Now insert any sim card in phone and do factory reset with reset cach than use C3300k cable for UART connection. Ofcourse with phone on condition not with off condition.
The Following User Says Thank You to ashraf_bcs For This Useful Post:
Old 10-22-2014, 19:24   #74 (permalink)
Member: 1625194
Thanks Meter: 30
I will try and post result
Old 10-24-2014, 14:16   #75 (permalink)
Member: 2093517
Thanks Meter: 25
i sloved prob with octpus
Page generated in 0.39952 seconds with 7 queries
