12-21-2009, 17:17 | #1 (permalink) |
Freak Poster Join Date: Aug 2007 Location: Turkey-Isparta
Member: 565843 Status: Offline Thanks Meter: 14 | s3650 imei problem [SOLVED] and one of s8000 has a different problem. i m writing imei and do *#06# it shows the imei that i write but when i do *#06# second time it shows old imei. is there any solution? Last edited by wgmmmx1; 02-22-2010 at 22:24. |
12-21-2009, 21:54 | #2 (permalink) | |
Moderator Join Date: Oct 2009 Location: Poland Age: 42
Member: 1139057 Status: Offline Sonork: 100.109924 Thanks Meter: 4,428 | Quote:
About S3650 just write firmware with boot S3650XXIE5 and after repeat procedure and all will work now not all software are supported but soon, very soon all will work. bye | |
12-22-2009, 09:54 | #4 (permalink) |
Banned Join Date: Jun 2007 Location: Samsung
Member: 535033 Status: Offline Sonork: 100.45908 Thanks Meter: 18,871 | if its say header error u must use rj45+usb combo cable and before process must reset phone *2767*3855# then later can write and check phone imei must be after patch imei not active or 000000 if not mean u not doing patch right |
The Following User Says Thank You to SPTTEAM For This Useful Post: |
12-22-2009, 19:23 | #6 (permalink) |
Member: 535033 Status: Offline Sonork: 100.45908 Thanks Meter: 18,871 | just download s3650xxie5 from support select all file with boot and mark reset mslcode 16 then after flash done just select boot file without mark reset mslcode 16 and after done connect phone to combo cable (rj45+usb) phone must be powered then select box port and mark imei + unlock and press factory mode thats all B.R |
12-23-2009, 10:57 | #7 (permalink) |
Member: 565843 Status: Offline Thanks Meter: 14 | Detect Modem Connect ... Modem Connect OK. Detect Comport Connect ... Comport Connect OK. SW Ver: S3650XXII5 IMEI: 3548810....... BTID: 60D0A9-058F93 S/N: R8YS9xxx Please Wait Calc LockCode ... Check MSL Code Failure ! Total Time: 45.54 s and i m trying go to support for s3650xxie5 file but when i press go to support button the page says "For Login Support Area Use Inside Sw Go To Support Area Button. " or can u give a link for rhis file? Last edited by crazyexistenz; 12-23-2009 at 11:07. |
12-23-2009, 11:27 | #10 (permalink) |
Junior Member Join Date: Apr 2003 Location: www.3grpl.com Age: 47
Member: 25717 Status: Offline Sonork: 100.1585253 Thanks Meter: 4 | Hi,Brother you need login Sptbox support. http://support.sptbox.com ///SPT///Flash Files///UMTS///GT-S3650///S3650XXIJ3.rar B.R. Gsmcdma |
12-23-2009, 11:34 | #11 (permalink) |
Member: 565843 Status: Offline Thanks Meter: 14 | when i press the go to support button it says For Login Support Area Use Inside Sw Go To Support Area Button if u have the file plz give me a link for s3650xxie5 |
s3650 imei problem | crazyexistenz | Z3X-Team Products | 16 | 06-20-2011 23:46 |
how to s3650 imei 0000000000 repair [SOLVED] | turkcellgsm | SPT BOX | 2 | 03-10-2010 08:06 |
s3650 unlock problem[SOLVED] | ele22 | SPT BOX | 12 | 01-23-2010 11:44 |
gt-s3653 flash file & rebuild imei problem.[Solved] | LoneWolf37 | SPT BOX | 3 | 11-13-2009 15:09 |
BE4 Change IMEI problem solved! | expert | Alcatel & TCL Old Models | 24 | 02-25-2004 13:21 |
