04-29-2014, 11:16 | #1 (permalink) |
No Life Poster Join Date: Jun 2004 Location: Kenya
Member: 70343 Status: Offline Thanks Meter: 38 | 19500 efs problem I need an efs file for s4, i9500. I need in tar format, to flash with odin as the phone hangs at logo. Anyone with this file, please help... Thanks!!! |
04-29-2014, 12:13 | #2 (permalink) |
Insane Poster Join Date: Oct 2003 Location: Europe Age: 50
Member: 42007 Status: Offline Thanks Meter: 1 | I have a major problem trying to repair EFS on I9500. Knox keeps blocking SU in Android 4.3. If I downgrade to 4.2.2, do IMEI repair it shows 0044... but then take it back to 4.3 and IMEI and SN seem fine, signal shows fine and can make emergency calls but not registered on network. Can anyone recommend the correct flash files and IMEI rewrite procedure to get this sorted out. Once an S4 has been flashed to 4.3 is there anyway to downgrade it and repair the EFS area? How do I prevent Knox from messing around the repair procedure? Thanks |
04-29-2014, 13:29 | #3 (permalink) |
Freak Poster Join Date: May 2013 Location: Turkey
Member: 1941192 Status: Offline Thanks Meter: 57 | i9500 new security EFS_I9500_24-4-2014_15-7-4 |
The Following User Says Thank You to mestoo1 For This Useful Post: |
04-30-2014, 12:03 | #6 (permalink) | |
Member: 70343 Status: Offline Thanks Meter: 38 | Quote:
04-30-2014, 15:32 | #7 (permalink) |
Member: 1941192 Status: Offline Thanks Meter: 57 | root your device 1. Phone must be powered on. 2. Enable "USB debugging" in "Settings"-"Developer options". To enable "Developer options" for Android 4.3+ go to "Settings"-"About phone" and tap on "Build Number" 7 times. 3. Type on phone *#0808# and choose "MTP + ADB". |
05-02-2014, 12:51 | #8 (permalink) | |
05-03-2014, 09:28 | #9 (permalink) |
Member: 42007 Status: Offline Thanks Meter: 1 | I tried this file but it does not appear to help at all. IMEI null/null after upload and security function still blocking any SU activity and preventing IMEI repair. Should I try to downgrade this phone to 4.2.2. to fix it or still keep fighting with 4.3? |
05-03-2014, 12:15 | #10 (permalink) | |
Member: 1941192 Status: Offline Thanks Meter: 57 | Quote:
