05-07-2009, 10:47 | #1 (permalink) |
No Life Poster Join Date: Apr 2004 Age: 62
Member: 63042 Status: Offline Thanks Meter: 117 | 730sc IMEI FFFF after/before flash to supported version First when it was read imei and version unsupported so as normal procedure we flashed to the supported version. Both files 730SCID2.crp and 730SCIA3.crp were used and still same problem .. IMEI unknown but units when checked had valid IMEI... Both are Jan 2009 model... I tried old Qualcomm 5.3.2 and new 5.4 same results Used on 2nd PC also same results Need your comment.... |
05-07-2009, 11:31 | #2 (permalink) |
Freak Poster Join Date: Mar 2006 Location: japan
Member: 248942 Status: Offline Sonork: 100.1590361 Thanks Meter: 455 | is this your first try? This log is very strange I wanna know phone infomation using USB cable only Maybe com cable problem Post USB log please Andy_jpn |
05-07-2009, 11:45 | #3 (permalink) |
No Life Poster Join Date: Aug 2006 Location: manila, philippines
Member: 336741 Status: Offline Thanks Meter: 152 | i already check his 2 units...one is supported 730SCHI6 and the other is 730SCDI2 w/c is not supported... i think need to fixed some problem in the new version... he will post the screenshots later... error in unlocking...it can be flashed to the same version but not in lower version it failed... br, mawxep03 Last edited by mawxep03; 05-07-2009 at 11:51. |
05-07-2009, 13:36 | #4 (permalink) |
Member: 63042 Status: Offline Thanks Meter: 117 | @andy jon This is not my first time to unlock had done successful on 5 units ! Cable Rj is fine and working... Due to my curiousity for this problem, I brought the same 2 units and my box for a test courtesy of Mawxep and surprisingly all units are ok when read phone info . Will have to sort out tom my problem and double check my cable first... But... We have a new problem with the new flash files uploaded "730SCID2.crp" , after trying flashing it and using latest qualcomm tool 5.4 .... Error in unlocking at 98% .......Pls check my screenshots to proved still not supported with the new version... |
05-07-2009, 16:19 | #6 (permalink) |
Freak Poster Join Date: Sep 2004 Location: Manila,Phillipines Age: 56
Member: 84177 Status: Offline Thanks Meter: 29 | @ rakishi master, this is what i've been telling you....pls read....http://forum.gsmhosting.com/vbb/showthread.php?t=745062 maybe your technician accidentally flashed it to a higher version(730scid2)...now downgrade is not posible yet....you must wait for the next update according to sir blang....good luck sir.... Last edited by hans0001; 05-07-2009 at 16:28. |
The Following User Says Thank You to hans0001 For This Useful Post: |
05-08-2009, 02:15 | #7 (permalink) | |
Freak Poster Join Date: Feb 2005 Age: 46
Member: 121368 Status: Offline Thanks Meter: 3 | Quote:
this is so em*****ing its my first time to unlock the unit and the phone imei turns to 000000000000000 so ive asked question to my fellow technician here in the phillipines he said that i would flash it to the other firmware (730scid2) and there i could perform unlock then after flash it back to patch network and camera files.....but this wrong information this version is not supported..........tsk tsk tsk now phone is useless | |
05-08-2009, 03:40 | #8 (permalink) | |
Member: 84177 Status: Offline Thanks Meter: 29 | Quote:
05-08-2009, 06:46 | #9 (permalink) |
Member: 63042 Status: Offline Thanks Meter: 117 | Need expert to explain this... Today I found my problem re IMEI FFFFF .... Only on my 2 Computers having this problem the rest PC no problem .. No problem when using USB interface Problem arises when using COM... it changes from device manager Com settings 100 ( in my pc) but after switch to 1 ... How to fix this ??? I hope Z3x team can help with this... |
Help! 1100 IMEI ??????????????4 after erase flash and reflash! | Bloodware | Nokia Hardware & Hardware Repair | 23 | 11-30-2010 15:27 |
6300 SPANISION flash ic supported version 5.50 with v030 !! !! | wgmmmx | BB5BOX | 2 | 01-09-2008 19:12 |
Backup before flashing to N80IE? | thomaslehner | Nokia Base Band 5 ( BB-5 ) | 0 | 01-20-2007 13:15 |
Dead, Missing, No Imei 3310 After Griffin Flash | genecola | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 10 | 08-15-2006 16:52 |
