02-27-2022, 14:27 | #1 (permalink) |
Junior Member Join Date: Jan 2015 Location: Dubai
Member: 2336444 Status: Offline Thanks Meter: 1 | A205F Error Unlocking [Answered] To read security codes using sever: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone'-'Software information' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, select 'Read codes ...' algo, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings.) Operation: Read Codes via Server [UPLOAD 2021] Selected model: SM-A205F Software version: 43.27 Checking Login and Password... OK Balance: 30 crd. You have 30 credit(s) left. This operation takes 5 credits. Attention! In case if phone asking MCK code, using this method will consume credits twice - first for MCK code and then for NCK. Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-A205F Android version: 10 PDA version: A205FXXSABUB1 CSC version: A205FOJMABUB1 Phone version: A205FDDSABUB1 Product code: SM-A205FZKGKSA CSC country code: KSA CSC sales code: KSA Carrier ID: KSA Phone SN: R58M50RMRZA IMEI: 357086105628398 HW version: REV0.3 RF cal date: 20190504 Chip name: EXYNOS7884B Modem board: SHANNON327 Security patch: 2021-03-01 Boot Warranty bit: 0 SIM State: ABSENT,ABSENT Rebooting phone... OK Waiting ADB device... OK Waiting for device to become ready... OK Initialization zTool Loader... OK Running zTool, please wait... OK Loading... OK Initialization zTool... OK Running zTool, please wait... OK Reading lock state... OK Checking SIM status... OK Executing... OK Searching Ramdump interface... COM5 detected Rebooting phone... OK Waiting ADB device... OK Waiting for device to become ready... OK Reading ramdump data from phone... OK Calculating... error (1) Could not find data. Please try again. Done with Samsung Tool PRO v.43.27 [SM-A205F,Read Codes via Server [UPLOAD 2021]] |
02-28-2022, 06:36 | #4 (permalink) |
Member: 2336444 Status: Offline Thanks Meter: 1 | FLASH INSTRUCTIONS: 1. Choose correct flash file(s). 2. If you have PIT file chosen, then you must check 'Repartition' option. 3. Check flashing options if needed (Repartition, EFS clear, Boot update). 4. Power on the phone in download mode (turn off phone, press vol.up + vol.down and insert USB cable). 5. Connect the phone to PC with USB cable, install drivers if needed. 6. Press 'Flash' button. Operation: Read Codes via Server [Mar 2020] Selected model: SM-A205F Software version: 43.27 Checking Login and Password... OK Balance: 30 crd. You have 30 credit(s) left. This operation takes 5 credits. Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-A205F Android version: 10 PDA version: A205FXXSABUB1 CSC version: A205FOJMABUB1 Phone version: A205FDDSABUB1 Product code: SM-A205FZKGKSA CSC country code: KSA CSC sales code: KSA Carrier ID: KSA Phone SN: R58M50RMRZA IMEI: 357086105628398 HW version: REV0.3 RF cal date: 20190504 Chip name: EXYNOS7884B Modem board: SHANNON327 Security patch: 2021-03-01 Boot Warranty bit: 0 SIM State: ABSENT,ABSENT Initialization zTool... OK Running zTool, please wait... OK Reading data from phone... error (5 4.1) Unlock method is not supported, use another method Done with Samsung Tool PRO v.43.27 [SM-A205F,Read Codes via Server [Mar 2020]] |
02-28-2022, 06:36 | #5 (permalink) |
02-28-2022, 06:37 | #6 (permalink) |
Member: 2336444 Status: Offline Thanks Meter: 1 | I already did reset but still same FLASH INSTRUCTIONS: 1. Choose correct flash file(s). 2. If you have PIT file chosen, then you must check 'Repartition' option. 3. Check flashing options if needed (Repartition, EFS clear, Boot update). 4. Power on the phone in download mode (turn off phone, press vol.up + vol.down and insert USB cable). 5. Connect the phone to PC with USB cable, install drivers if needed. 6. Press 'Flash' button. Operation: Read Codes via Server [Mar 2020] Selected model: SM-A205F Software version: 43.27 Checking Login and Password... OK Balance: 30 crd. You have 30 credit(s) left. This operation takes 5 credits. Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-A205F Android version: 10 PDA version: A205FXXSABUB1 CSC version: A205FOJMABUB1 Phone version: A205FDDSABUB1 Product code: SM-A205FZKGKSA CSC country code: KSA CSC sales code: KSA Carrier ID: KSA Phone SN: R58M50RMRZA IMEI: 357086105628398 HW version: REV0.3 RF cal date: 20190504 Chip name: EXYNOS7884B Modem board: SHANNON327 Security patch: 2021-03-01 Boot Warranty bit: 0 SIM State: ABSENT,ABSENT Initialization zTool... OK Running zTool, please wait... OK Reading data from phone... error (5 4.1) Unlock method is not supported, use another method Done with Samsung Tool PRO v.43.27 [SM-A205F,Read Codes via Server [Mar 2020]] |
