06-19-2017, 08:06 | #1 (permalink) |
Freak Poster Join Date: May 2008
Member: 779599 Status: Offline Thanks Meter: 59 | samsung n7502 hang up help heres my logs FLASH INSTRUCTIONS: 1. Choose correct flash file(s). 2. If you have PIT file chosen, then you must check 'Repartition' option. 3. Check flashing options if needed (Repartition, EFS clear, Boot update). 4. Power on phone in download mode (turn off phone, press vol.down + home + power). 5. Connect phone to PC with USB cable, install drivers if needed. 6. Press 'Flash' button. Operation: Flash Selected model: SM-N7502 Software version: 28.1 File analysis... Ok Total file size: 0x269A7B9C (617 Mb) Searching USB Flash interface... COM62 detected Setup connection... error It looks like you have an unsucessful operation, try this link for solution - inurl:f453 site:http://forum.gsmhosting.com/ "Selected model: SM-N7502" "Setup connection error" - Пошук Google Done with Samsung Tool PRO v.28.1 i tried to flash with the same firmware but sadly it cant why pls help |
06-19-2017, 11:07 | #2 (permalink) |
Member: 779599 Status: Offline Thanks Meter: 59 | when i go to download mode it appears on the screen at the top that write protection enable i dont know how to fix this. team is it possible to fix this problem by flashing ? if possible how? pls help thanks |
06-19-2017, 11:11 | #3 (permalink) |
Member: 779599 Status: Offline Thanks Meter: 59 | team, when i go to download mode it appears on the screen at the top that write protection enable. i dont know hw to fix this problem. team is it posible to fix this problem by flashing even it is protected? if possible how? pls help. |
