07-05-2016, 17:36 | #1 (permalink) |
No Life Poster Join Date: Oct 2006 Location: yaoundé (av kennedy)
Member: 361348 Status: Offline Thanks Meter: 635 | A310 write cert file Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore. 6. Press 'Read CERT' button to read certificates or 'Write CERT' to restore. 7. Press 'Write NV DATA' if you need to restore NV backup. Operation: Write CERT Selected model: SM-A310F Software version: 25.9 Waiting ADB device... Please, allow USB debugging on phone... OK Reading phone info... Model: SM-A310F Android version: 5.1.1 Product code: SM-A310FZKAPRO Phone version: A310FXXU1AOLE PDA version: A310FXXU1AOLE CSC version: A310FVFG1AOL2 CSC country code: Belgium CSC sales code: PRO HW version: MP 0.200 Phone S/N: R28H3060WML Modem board: SHANNON310 RF cal date: 20160302 IMEI: Checking Super user right... true Initializating zTool... OK Running zTool, please wait... Start... OK Init... OK Generate and check client proof... OK Verify proof by client... OK Reading data... OK HWID: 7C 52 6F D5 C8 E1 F2 A6 19 CA B7 88 F8 BA B5 9D Checking certificate file... OK KEY ID: 0017 Reading nv data... OK Checking NV data... OK Calculating... OK Writing nv data... OK Rebooting phone... OK Write CERT done Done with Samsung Tool PRO v.25.9 |
The Following User Says Thank You to hippolyte85 For This Useful Post: |
