Old 02-01-2017, 16:07   #1 (permalink)
bherkund's Avatar
Member: 1119917
Sonork: nedi
Thanks Meter: 190
a310f drk fix error
REPAIR INSTRUCTIONS:
Phone must be rooted!
If the software can't root the phone automatically,
then you must root your device manually.
1. Power on the phone.
2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options',
go to 'Settings'-'Developer options' and enable 'USB debugging'.
3. Connect the phone to PC with USB cable, install drivers if needed.
4. Select device in ADB settings.
5. Fill values what you need to repair.
6. Press 'Repair' button.
7. Press 'Patch Certificate' if you have network problem after repairing.
7. Press 'Reset EFS' if you need to reset it.
Be carefully, do not perform this without necessity. Backup will be created automatically.
Repair DRK (Use it if you have DRK damaged (phone stuck on boot)):
1. Power on phone in download mode (turn off phone, hold vol.down + Camera + Power).
2. Connect phone to PC with USB cable, install drivers if needed.
3. Press 'Repair DRK' button.
Operation: Repair DRK
Selected model: SM-A310F
Software version: 27.7
Checking local file... Ok
Searching server... Ok
Compare local and server file... OK (up to date)
Searching USB Flash interface... COM55 detected
Setup connection... Ok
Reading data from phone... Ok
Sending data to phone... error timeout
Done with Samsung Tool PRO v.27.7
Old 02-02-2017, 07:37   #2 (permalink)
bherkund's Avatar
Member: 1119917
Sonork: nedi
Thanks Meter: 190
problem solved please close this thread.
Old 02-02-2017, 07:50   #3 (permalink)
pitbulli's Avatar
Member: 1475192
Thanks Meter: 121
Explain how fix the problem, it will be useful to many people here in forum .
Old 02-02-2017, 10:21   #4 (permalink)
farukpdm's Avatar
Member: 1417131
Sonork: Uninstalled
Thanks Meter: 1,090
try just root..............................
Old 12-16-2019, 19:43   #5 (permalink)
Member: 2777649
i have same problem...
Old 12-17-2019, 21:23   #6 (permalink)
Moderator
Member: 1139057
Sonork: 100.109924
Thanks Meter: 4,428
Write combination firmware to phone then enable usb debugging in phone and repair drk with z3x will work without problems.
__________________
Please do not Personal Message me for help or troubleshooting. They will be ignored. Use the forums!
To get Instant help use "search" & follow "sticky thread"..!!!
By respecting/following forum rules,You will be respected .!
Page generated in 0.15912 seconds with 8 queries
