a310f frp unlock Hi i want to unlock frp on a310 . i downloaded the combination file but i cannot choose as zip file . i unzipped it and it has 2 files inside how to put this to Software the big one i choosed as pda buit the second one i dont know how to put it. i wanted to choose it as boot file but i dont want to destroy the phone |
flash the first one the big one if not working flash the other one too in pda |
it flashed the small one but adb is not activated i tried to big one and i get FLASH INSTRUCTIONS: 1. Choose correct flash file(s). 2. If you have PIT file chosen, then you must check 'Repartition' option. 3. Check flashing options if needed (Repartition, EFS clear, Boot update). 4. Power on phone in download mode (turn off phone, press vol.down + home + power). 5. Connect phone to PC with USB cable, install drivers if needed. 6. Press 'Flash' button. Operation: Flash Selected model: SM-A310F Software version: 27.0 File analysis... ok Total file size: 0x3A915088 (937 Mb) Searching USB Flash interface... COM5 detected Setup connection... ok Reading PIT from phone... ok Sending sboot.bin... error timeout Done with Samsung Tool PRO v.27.0 |
DO NOT CHOOSE THE SMALL FILE AS BOOT! It will kill your phone and you'll have to restore it with the official firmware. |
a310f frp not working Try with combination file from support area but no luck seams frp unlock not working for latest security: Operation: Flash Selected model: SM-A310F Software version: 27.4.2 File analysis... Ok Total file size: 0x27300D98 (627 Mb) Searching USB Flash interface... COM6 detected Setup connection... Ok Reading PIT from phone... Ok Sending sboot.bin... error timeout Done with Samsung Tool PRO v.27.4.2 hope so new update will support latest security...and z3x will be first |
if u flash without sboot the set dont boot anymore |
can somebody give a clear instructions to remove frp on a310f. i saw lots of people have problems with it. why dont z3x team give a clear instruction? which files to use ? should we downgrade. if yes which combination file? thanks a lot |
http://forum.gsmhosting.com/vbb/f453.../#post12280856 PLEASE CLICK ON THE THANKS BUTTON IF THE POST IS HELPFULL |
Afther few try when i receive the sboot eroor, i find a combination for my A310 who work, afther that phone start with FACTORY BINARY and some strange menu, the frp on the soft say it is done, i make factory reset from the seting but phone still frp on, is something wrong? |
OK, let me see if i understand 1. factory binary is ok 2. in factory binary do frp reset 3. swich in flash mode and flash original firmware 4. now i have adb and reset again frp 5. go setings and make factory reset 6. done |
like i suspect, not working, afther flash original firmware no adb port |
Samsung SM-A310F 7.0 FRP Remove With Odin |
