10-22-2016, 21:10 | #1 (permalink) |
Registered User Join Date: Aug 2003 Location: ALGERIA ,DZ
Member: 37521 Status: Offline Thanks Meter: 50 | A310F FRP unlock problem even use combo file I have A310F with frp lock activated try to flash with combo file and reset frp with z3x then hard reset phone in menu but always FRP is ON (on download mode) I try this 10's times but no luck is there a real solution from everyone of you or Z3X team thanks all. |
10-23-2016, 09:45 | #3 (permalink) |
No Life Poster Join Date: Sep 2015 Location: Everywhere Age: 29
Member: 2454192 Status: Offline Sonork: 100.1674433 Thanks Meter: 693 | try to rest with real try 1.Download and installRealTerm program 2.Download and copy com.rootjunky.frpbypass-1.0.apk to the device micro sdcard or download once into the device. 3.Start phone and connect to WIFI also plug into the computer with your usb cable. 4.Start RealTerm on your pc and under pisplay check the box HALF DUPLEX 5.Right click on my computer and select manage once it opens click device manager then modems 6.Under modems you should see a Samsung device. right click it then select properties 7.Once the properties window opens select modem tab and see what port it is on like com5 for an example 8.Now that you know the com port number close all device manager windows and open RealTerm again 9.Under the ports tab in RealTerm enter your port number then click change. 10.Next, click the send tab. you will need to send these two commands with the Send ASCII button 11.First at+creg?\r\n 12.Then atd1234;\r\n 13.Look at your phone and the dailer will pop up |
10-24-2016, 01:03 | #5 (permalink) | |
No Life Poster Join Date: Dec 2008
Member: 930280 Status: Offline Thanks Meter: 1,183 | Quote:
10-24-2016, 01:19 | #6 (permalink) | |
Freak Poster Join Date: May 2012 Location: Haiti, Port-Au-Prince, Carref.
Member: 1763284 Status: Offline Thanks Meter: 56 | Quote:
What u mean. Be precise... After flashing it over, was the phone booted in factory mode or not? Or the file hasn't been flashed at all? Sent from my SM-N930F using Tapatalk | |
10-24-2016, 01:21 | #7 (permalink) |
No Life Poster Join Date: Feb 2010 Location: Koronadal City, Ph/Riyadh, KSA
Member: 1240161 Status: Offline Thanks Meter: 159 | Z3x already gave you a solution. Your problem now is that, after you reset, it comes back again. It is simply because you did not manually OFF FRP in setting. Tick Enable OEM Unlock in developer options then reset. Even without resetting the phone, you can verify that the FRP is switched off when you enter download mode. |
10-24-2016, 03:07 | #8 (permalink) | |
The Following 2 Users Say Thank You to Castle2k For This Useful Post: |
10-25-2016, 09:46 | #11 (permalink) |
Member: 37521 Status: Offline Thanks Meter: 50 | finally solved. atd1234,\r\n working after insert sim in phone then continue with other steps until junky apk install in es file explorer always phone say " unfortunatley.... has stoped" means junky apk then I decide to use old bypass apk "Bypass any Samsung Google Account Lock.apk" then go to "backup and reset" in device menu then reboot after that all done ... phone working like a....charm thanks all |
