08-19-2016, 17:27 | #1 (permalink) |
Crazy Poster Join Date: Feb 2009 Location: Nogent-Le-Rotrou
Member: 983080 Status: Offline Thanks Meter: 13 | A310F Pattern Lock Here's log. Operation: Reset Pattern Lock Selected model: SM-A310F Software version: 26.4 Checking local file... not found Searching server... OK File not found on server for this model Done with Samsung Tool PRO v.26.4 It says " Failed to create file samsung_recovery.ini ". |
08-23-2016, 17:14 | #2 (permalink) |
Member: 983080 Status: Offline Thanks Meter: 13 | No any product supporter or manager take a look at this problem???? Why saying reset pattern lock is supported when it's not so??? What's the file samsung_recovery.ini??? |
08-23-2016, 18:00 | #3 (permalink) | |
No Life Poster Join Date: Nov 2014 Location: SLK Age: 33
Member: 2291450 Status: Offline Sonork: typing... Thanks Meter: 1,600 | Quote:
put this recovery file show as in this image in your z3x recovery folder https://drive.google.com/open?id=0B8...lliLUlnb19kejA | |
08-23-2016, 18:08 | #4 (permalink) |
Member: 983080 Status: Offline Thanks Meter: 13 | Thanks for reply. i did put the recovery directory inside the samsungtoolpro directory, it passed the file check. but now, new problem, phone won't boot, just showing "An error has occured while updating the device software. Use the emergency recovery function in the Smart Switch PC software." while resetting pattern lock, on the phone, an error is shown, the FRP lock has denied the reset. Do you have any idea on how i can make it alive, without losing data??? |
08-24-2016, 05:44 | #5 (permalink) |
Member: 2291450 Status: Offline Sonork: typing... Thanks Meter: 1,600 | You have to reset frp but for this model z3x not supported. To recover without data loss boot phone in to recovery mode check firmware version and download from sammobile and flash with z3x Sent from my HUAWEI SCC-U21 using Tapatalk |
