09-02-2019, 10:33 | #1 (permalink) |
No Life Poster Join Date: Feb 2007 Location: Armenia
Member: 448264 Status: Offline Thanks Meter: 78 | A320FL after every restart relocking Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button. Reading codes using sever: Warning! Knox warranty must be active (0x00)! If you have it voided (0x01(void)), then you can't unlock this phone using sever. 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Press 'Read Codes via server' button, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings) Operation: Read Codes via Server Selected model: SM-A320FL Software version: 37.0 Checking Login and Password... OK Ballance: 20 crd. You have 20 credit(s) left. This operation takes 5 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-A320FL Android version: 8.0.0 PDA version: A320FLXXU4CSD2 CSC version: A320FLXEF4CSD1 Phone version: A320FLXXU4CSD1 Product code: SM-A320FZKNXEF CSC country code: France CSC sales code: XEF Phone SN: RF8JB2ZHCDX IMEI: 353118098661617 HW version: MP 0.300 RF cal date: 20171123 Chip name: EXYNOS7870 Modem board: SHANNON315 Security patch: 2019-04-01 Boot Warranty bit: 1 SIM State: NETWORK_LOCKED Initialization zTool... OK Running zTool, please wait... OK Reading data from phone... OK Searching server... OK Checking server answer... OK Executing... OK Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Freeze code: 20491506 NET lock: 68353081 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.37.0 i flash with service firmware A320FLXXU4CSD2 again same after every restart must input code |
