08-11-2017, 11:48 | #1 (permalink) |
Freak Poster Join Date: Jun 2011 Location: Lagos Nigeria
Member: 1607473 Status: Offline Sonork: 100.1619160 Thanks Meter: 9 | A5 2017 Successfully Unlocked by Z3X Unlocking with original MSL code: 1. Phone must be powered on. 2. Type *#0808# and select 'DM+ACM+ADB'. 3. Run dialer and type *#0*# (service mode will apear). 4. Connect the phone to USB cable, choose correct COM port in port settings. 5. Press 'Unlock' button. 6. Paste MSL code in new opened window and press 'OK'. Reading codes using sever: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, write your login and password in window if it will apear. (Login and password will be saved as default after first input and can be changed in settings.) Operation: Unlock Selected model: SM-A520F Software version: 29.0 Searching Samsung modem... detected COM220 Reading phone info... OK Model: SM-A520F AP version: A520FXXU1APLL CSC version: A520FPHE1APLB CP version: A520FXXU1APLL Product code: SM-A520FZIAPHE Phone SN: R58J12QEGTH Unique number: CBJ10EDF76458B3 Reading IMEI... OK IMEI: 354607082288170 Reading SN... OK Phone SN: R58J12QEGT Enter MSL: 1A4F470347545F092D505F4751604214 Bypass MSL... OK Unlocking... OK Codes set to 00000000 Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.29.0 |
