04-11-2017, 15:46 | #4 (permalink) |
No Life Poster Join Date: Jan 2015
Member: 2325887 Status: Offline Thanks Meter: 134 | FLASH INSTRUCTIONS: 1. Choose correct flash file(s). 2. If you have PIT file chosen, then you must check 'Repartition' option. 3. Check flashing options if needed (Repartition, EFS clear, Boot update). 4. Power on phone in download mode (turn off phone, press vol.down + home + power). 5. Connect phone to PC with USB cable, install drivers if needed. 6. Press 'Flash' button. Operation: Flash Selected model: SM-A5000 Software version: 27.7 File analysis... Ok Total file size: 0x72ADDBA8 (1834 Mb) Searching USB Flash interface... COM62 detected Setup connection... Ok Reading PIT from phone... Ok Sending aboot.mbn... Ok Sending boot.img... Ok Sending cache.img.ext4... Ok Sending hyp.mbn... Ok Sending modem.bin... Ok Sending NON-HLOS.bin... Ok Sending recovery.img... Ok Sending rpm.mbn... Ok Sending sbl1.mbn... Ok Sending sec.dat... Ok Sending system.img.ext4... Ok Sending tz.mbn... Ok Flashing done (time - 00:04:49) Done with Samsung Tool PRO v.27.7 |
04-11-2017, 15:51 | #6 (permalink) |
Freak Poster Join Date: Feb 2017 Location: D.R
Member: 2684440 Status: Offline Thanks Meter: 218 | |
04-11-2017, 16:03 | #7 (permalink) |
Member: 2325887 Status: Offline Thanks Meter: 134 | BACKUP INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore or press 'Write CERT' to restore certificates. To backup/restore QCN, phone diagnostic port must be enabled. 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Type *#9090# and select 'DM/DUN over HSIC'. Or use 'Activate Diag' function from 'Repair' tab. 4. Connect phone to PC with USB cable, install drivers if needed. 5. Select diagnostic port in port settings. 6. Press 'Read QCN' button to read NV backup or 'Write QCN' to restore. Operation: Write EFS Selected model: SM-A5000 Selected port: COM38 SAMSUNG Mobile USB Serial Port Software version: 27.7 Waiting ADB device... Please, allow USB debugging on phone... Ok Reading phone info... Model: SM-A5000 Android version: 4.4.4 Product code: SM-A500FZWDCHC Phone version: A5000ZCU1ANJ2 PDA version: A5000ZCU1ANJ2 CSC version: A5000CHC1ANJ2 CSC country code: China CSC sales code: TGY HW version: Phone SN: Modem board: MSM8916 RF cal date: 2014.12.17 IMEI: Checking Super user right... true Extracting EFS file... Ok Converting Img to Ext4... Ok Writing EFS to phone... Ok Rebooting phone... Ok Done with Samsung Tool PRO v.27.7 |
04-11-2017, 16:13 | #8 (permalink) |
Member: 2325887 Status: Offline Thanks Meter: 134 | BACKUP INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore or press 'Write CERT' to restore certificates. To backup/restore QCN, phone diagnostic port must be enabled. 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Type *#9090# and select 'DM/DUN over HSIC'. Or use 'Activate Diag' function from 'Repair' tab. 4. Connect phone to PC with USB cable, install drivers if needed. 5. Select diagnostic port in port settings. 6. Press 'Read QCN' button to read NV backup or 'Write QCN' to restore. Operation: Write QCN Selected model: SM-A5000 Selected port: COM38 SAMSUNG Mobile USB Serial Port Software version: 27.7 Reading QCN file... OK Reading ID... OK Detected ID: 00000FFE (MSM8916) SW version: MPSS.DPM.1.0.c7.1-00037-M8916EAAAANVZM-1.6212.1.6340.1 Checking paths... OK Restoring EFS backup... OK Restoring NV items... OK Restoring NV item SIM1... OK Restoring NV item SIM2... OK Restoring Provisioning Item Files... OK Restore QCN done Done with Samsung Tool PRO v.27.7 |
