07-09-2015, 22:47 | #1 (permalink) |
No Life Poster Join Date: Dec 2004 Location: Algeria
Member: 96141 Status: Offline Thanks Meter: 200 | A500FU dead after succesfull downgrade ! i got a locked A500FU 5.0.2, so i downgrade it to 4.4.4 hopping to unlock, with (A500FUXXU1ANL6_A500FUOXX1ANL4_A500FUXXU1ANL5_HOME .tar.md5) after sucsessfully downgrade, the phone is completely dead ! no download mode, no recovery !! what's the peoblem with plz, nead help. thanks Code: FLASH INSTRUCTIONS: 1. Choose correct flash file(s). 2. If you have PIT file chosen, then you must check 'Repartition' option. 3. Check flashing options if needed (Repartition, EFS clear, Boot update). 4. Power on phone in download mode (turn off phone, press vol.down + home + power). 5. Connect phone to PC with USB cable, install drivers if needed. 6. Press 'Flash' button. Operation: Flash Selected model: SM-A500FU Software version: 21.7 File analysis... OK Total file size: 0x7A39A364 (1955 Mb) Searching USB Flash Interface... detected COM14 Setup connection... OK Reading PIT from phone... OK Sending aboot.mbn... OK Sending NON-HLOS.bin... OK Sending rpm.mbn... OK Sending sbl1.mbn... OK Sending tz.mbn... OK Sending boot.img... OK Sending recovery.img... OK Sending system.img.ext4... OK Sending modem.bin... OK Sending cache.img.ext4... OK Sending hidden.img.ext4... OK Flashing done (time - 00:05:02) Done with Samsung Tool PRO v.21.7 |
The Following User Says Thank You to .:bono:. For This Useful Post: |
07-14-2015, 00:29 | #10 (permalink) | |
Member: 96141 Status: Offline Thanks Meter: 200 | Quote:
Odin A500FU.JPG why z3x killed the phone ? | |
07-17-2015, 11:39 | #13 (permalink) |
No Life Poster Join Date: Oct 2004 Location: Budapest Age: 54
Member: 87188 Status: Offline Thanks Meter: 227 | Same problem!!! A500FU complete Dead after downgrade To 4.4.4 <ID:0/016> Added!! <OSM> Enter CS for MD5.. <OSM> Check MD5.. Do not unplug the cable.. <OSM> Please wait.. <OSM> A500FUXXU1AOB4_A500FUOXX1AOB1_A500FUXXU1AOB4_HOME. tar.md5 is invalid. <OSM> End... <OSM> Enter CS for MD5.. <OSM> Check MD5.. Do not unplug the cable.. <OSM> Please wait.. <OSM> A500FUXXU1AOB4_A500FUOXX1AOB1_A500FUXXU1AOB4_HOME. tar.md5 is valid. <OSM> Checking MD5 finished Sucessfully.. <OSM> Leave CS.. <ID:0/016> Odin engine v(ID:3.1005).. <ID:0/016> File analysis.. <ID:0/016> SetupConnection.. <ID:0/016> Initialzation.. <ID:0/016> Get PIT for mapping.. <ID:0/016> Firmware update start.. <ID:0/016> SingleDownload. <ID:0/016> aboot.mbn <ID:0/016> NAND Write Start!! <ID:0/016> NON-HLOS.bin <ID:0/016> rpm.mbn <ID:0/016> sbl1.mbn <ID:0/016> tz.mbn <ID:0/016> boot.img <ID:0/016> recovery.img <ID:0/016> system.img.ext4 <ID:0/016> modem.bin <ID:0/016> cache.img.ext4 <ID:0/016> hidden.img.ext4 <ID:0/016> RQT_CLOSE !! <ID:0/016> RES OK !! <ID:0/016> Remain Port .... 0 <OSM> All threads completed. (succeed 1 / failed 0) <ID:0/016> Removed!! What is this ****? I'll send the guarantee... |
07-18-2015, 06:44 | #14 (permalink) |
Member: 87188 Status: Offline Thanks Meter: 227 | This does not mean, without the EES is to boot.... It was the client's wish. For the lollipop useless. G900F a downgrade is not a problem. The A500FU I do not understand why you will permanently brick. |
07-22-2015, 09:38 | #15 (permalink) | |
No Life Poster Join Date: Mar 2010 Location: unlockprice.com
Member: 1263622 Status: Offline Thanks Meter: 149 | Quote:
The Following User Says Thank You to Rotan Sarkar For This Useful Post: |
