09-04-2017, 16:01 | #1 (permalink) |
No Life Poster Join Date: Nov 2009 Location: India
Member: 1152038 Status: Offline Thanks Meter: 257 | A500FU Read Codes via Server UNLCOK DONE Micro-USB cable: 1. Phone must be powered on. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Type *#9090# and choose 'DM/DUN over HSIC' (ignore it, if it's not available). 4. Reboot phone. Or use 'Activate Diag' function from 'Repair' tab. 5. Connect USB cable, install drivers if needed. 6. Select Samsung diagnostic port in port settings. 7. Press 'Unlock' button for direct unlock. Reading codes using sever: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, write your login and password in window if it will apear. (Login and password will be saved as default after first input and can be changed in settings.) Operation: Read Codes via Server Selected model: SM-A500FU Selected port: COM40 SAMSUNG Mobile USB Serial Port Software version: 29.2 Checking Login and Password... OK Ballance: 50 crd. Waiting ADB device... OK Reading phone info... Model: SM-A500FU Android version: 6.0.1 Product code: SM-A500FZKUVIR Phone version: A500FUXXU1CPH3 PDA version: A500FUXXS1CQC4 CSC version: A500FUVIR1CPH1 CSC country code: UK CSC sales code: VIR HW version: MP 0.200 Phone SN: RF8G31WXXX Chip name: MSM8916 Modem board: MSM8916 Security patch: 2017-03-01 RF cal date: 2015.03.25 IMEI: Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Searching Ramdump interface... COM3 detected Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Freeze code: 31720259 NET lock: 14707179 SUB lock: 00000000 SP lock: 07462819 CP lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.29.2 THANK YOU Z3X TEAM ... |
