06-01-2017, 12:39 | #1 (permalink) |
No Life Poster Join Date: May 2010 Location: india
Member: 1300517 Status: Offline Sonork: 100.1601031 Thanks Meter: 104 | a510 6.0.1 unlock help nned To unlock NEW security type: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button and select 'New Unlock' for direct unlock. To unlock OLD security type: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Unlock' button and select 'Unlock' for direct unlock. To read security codes (all security types): 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Read codes' button to read security codes. To reset Pattern lock: 1. Power on phone in download mode (turn off phone, press vol.down + home + power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Reset Pattern Lock' button. To reset Google account activation or Samsung reactivation lock: 1. ADB must be activated in any way (you can flash sBoot from combination firmware, make sure, that you are not upgrade sBoot). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Select device in ADB settings. 4. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Read Codes Selected model: SM-A510FD Software version: 28.2 Waiting ADB device... Ok Reading phone info... Model: SM-A510F Android version: 6.0.1 Product code: SM-A510FZWFKSA Phone version: A510FDXXU4BQC3 PDA version: A510FXXU4BQC2 CSC version: A510FDOJP4BQC3 CSC country code: KSA CSC sales code: KSA HW version: MP 0.000 Phone SN: R58H95JTKRR Chip name: EXYNOS7580 Modem board: SHANNON310 Security patch: 2017-03-01 RF cal date: 20160929 IMEI: Operation aborted Done with Samsung Tool PRO v.28.2 |
06-01-2017, 13:47 | #2 (permalink) |
Member: 1300517 Status: Offline Sonork: 100.1601031 Thanks Meter: 104 | after write modem imei notshow bb unkown also File analysis... Ok Total file size: 0x020C17D0 (32 Mb) Searching USB Flash interface... COM40 detected Setup connection... Ok Reading PIT from phone... Ok Sending modem.bin... Ok Flashing done (time - 00:00:04) Done with Samsung Tool PRO v.28.2 |
