10-10-2016, 14:37 | #1 (permalink) |
No Life Poster Join Date: Oct 2008 Location: Noise City
Member: 889564 Status: Offline Thanks Meter: 336 | >>> A510F can't flash after Combination file <<< I had to reset the FRP of this Samsung A510F, so I first flash it with COMBINATION_FAC_FA51_A510FXXU3API1, then "Rest FRP" with Z3X, but now, when I try to flash it with "normal" rom (from the support area) , so I can revive the set, Z3X gives me this error: Code: File analysis... OK Total file size: 0xA6E0C280 (2670 Mb) Searching USB Flash interface... COM9 detected Setup connection... OK Reading PIT from phone... OK Sending boot.img... OK Sending cache.img... OK Sending cm.bin... error timeout Done with Samsung Tool PRO v.26.9 I tried different firmwares, but always end up with this error... Any ideas, mates? |
10-11-2016, 09:43 | #6 (permalink) |
Member: 889564 Status: Offline Thanks Meter: 336 | @igma, I tried with Kies, but no luck - again this SYSTEM REV. CHECK FAIL DEVICE: 3, BINARY: 2 Any other ideas? Support team? Anybody?! Why can't I flash the phone after this combination file?! FRP IS NOT DONE and now I can't even revive the set!? Wtf?! |
10-11-2016, 12:41 | #8 (permalink) |
Member: 889564 Status: Offline Thanks Meter: 336 | @xerraco, I did, mate, but It's the same situation - SYSTEM REV. CHECK FAIL DEVICE: 3, BINARY: 2 . The set just can't be flashed anymore. Im running out of ideas, that's why Im asking here how return to original/alive state. The only thing that the phone accepts, without any errors during flash, is this COMBINATION_FAC_FA51_A510FXXU3API1 file. Nothing else! |
10-11-2016, 16:48 | #9 (permalink) |
No Life Poster Join Date: Jun 2007 Location: Swansea, UK Age: 41
Member: 523318 Status: Offline Thanks Meter: 268 | Hi. What does it mean "normal" flash for You? More details please. Have U tried with A510FXXU3BPIB? http://www.**************/firmwares/...FTEF3BPI5_O2U/ This error looks like U want do downgrade. |
The Following User Says Thank You to ProcyOne For This Useful Post: |
10-12-2016, 04:27 | #11 (permalink) |
No Life Poster Join Date: Nov 2013 Location: Third World ;)
Member: 2061381 Status: Offline Sonork: 100.1673769 Thanks Meter: 129 | Try to flash unselecting "sboot.bin" and "cm.bin" partitions. Acording logs you want to downgrade, so try to flash all other partitions except that two. |
The Following User Says Thank You to joel_3mo For This Useful Post: |
10-12-2016, 09:02 | #13 (permalink) |
Freak Poster Join Date: Dec 2009 Location: @India
Member: 1176826 Status: Offline Sonork: 100.1604160 Thanks Meter: 60 | I have Same Problem In J700F I am Trying To Flash Original Firmware And It Gives Error "Custom Binary Blocked By FRP " Usually it comes in read color but in my case showing In Green Color... I used latest firmware 6.0.1 i used lollipop firmware i used combination firmware i tried single single partition.. |
10-12-2016, 09:23 | #14 (permalink) |
Member: 889564 Status: Offline Thanks Meter: 336 | Ok, mates, I did it - I managed to revive this A510F with A510FXXU3BPIB_A510FTEF3BPI5. I had some issues though - the flash process again stops (without those red lines, that indicates downgrading), but this time at hidden.img..., so I had to remove this part from the flash file and voila - everything was fine. The phone is alive now. @souloxo, you can find yours here https://samsung-firmware.org/model/SM-A510F/page/1 |
The Following User Says Thank You to DundyTM For This Useful Post: |
