Old 05-15-2017, 07:13   #1 (permalink)
Member: 2325887
Thanks Meter: 134
Thumbs up a510f flash error
problem is hang in logo samsung
FLASH INSTRUCTIONS:
1. Choose correct flash file(s).
2. If you have PIT file chosen, then you must check 'Repartition' option.
3. Check flashing options if needed (Repartition, EFS clear, Boot update).
4. Power on phone in download mode (turn off phone, press vol.down + home + power).
5. Connect phone to PC with USB cable, install drivers if needed.
6. Press 'Flash' button.
Operation: Flash
Selected model: SM-A510F
Software version: 27.8
File analysis... Ok
Total file size: 0x9C69FD70 (2502 Mb)
Searching USB Flash interface... COM91 detected
Setup connection... Ok
Reading PIT from phone... Ok
Sending sboot.bin... Ok
Sending cm.bin... error timeout
It looks like you have an unsucessful operation, try this link for solution - inurl:f453 site:http://forum.gsmhosting.com/ "Selected model: SM-A510F" "Sending cm.bin error timeout" - Пошук Google
Done with Samsung Tool PRO v.27.8
Old 05-15-2017, 07:14   #2 (permalink)
Member: 2325887
Thanks Meter: 134
i see error
SW REV. CHECK FAIL DEVICE; 3. BINARY;2
Old 05-15-2017, 07:18   #3 (permalink)
Member: 579725
Sonork: 100.1675677
Thanks Meter: 96
Flash your phone with letest verion ,, Sw rev check fail menz u are doing downgrade ,,
A510f lestest
Old 05-15-2017, 07:19   #4 (permalink)
Asad ali khan's Avatar
Member: 2454192
Sonork: 100.1674433
Thanks Meter: 693
Originally Posted by mahi20015 View Post
i see error
flash this firmware 100% tested
Download
Old 05-15-2017, 09:49   #5 (permalink)
Member: 2325887
Thanks Meter: 134
I download this firmware but again error plz help me
Old 05-15-2017, 14:09   #6 (permalink)
Member: 2454192
Sonork: 100.1674433
Thanks Meter: 693
write combination files then again make full flash with this firmware
Old 04-27-2018, 19:03   #7 (permalink)
Member: 2475584
Thanks Meter: 6
try tis firmware 100% working android 7
LinkShrink.net - Earn money sharing shrinked links!
Old 04-27-2018, 19:48   #8 (permalink)
Mounir's Avatar
Member: 58969
Thanks Meter: 56
what is the password
Br Mounir
Old 05-07-2018, 13:36   #9 (permalink)
Member: 2824933
Thanks Meter: 10
SM-A510F Done with Samsung Tool PRO v.31.5.1
Operation: Flash
Software version: 31.5.1
File analysis... OK
Total file size: 0xAAB10210 (2731 Mb)
Searching USB Flash interface... COM10 detected
Setup connection... OK
Reading PIT from phone... OK
Sending sboot.bin... OK
Sending cm.bin... OK
Sending boot.img... OK
Sending recovery.img... OK
Sending system.img... OK
Sending cache.img... OK
Sending hidden.img... OK
Sending modem.bin... OK
Flashing done (time - 00:02:11)
download letest firmware from sammobile
https://www.**************/firmwares/
Old 05-14-2018, 11:54   #10 (permalink)
teletalk's Avatar
Member: 926215
Sonork: 100.1650776
Thanks Meter: 95
i have same problem i samsung a510fd
Operation: Flash
Selected model: SM-A510FD
File analysis... OK
Total file size: 0x9C73C290 (2503 Mb)
Searching USB Flash interface... COM64 detected
on mobile display saw this error
SW REV.CHECK FAIL DEVICE:5 BINARY :3
so try to flash with android 7.0 but flashing failed
Old 05-14-2018, 12:15   #11 (permalink)
Absar_Global's Avatar
Member: 1442705
Thanks Meter: 1,061
Operation: Flash
File analysis... OK
Try to flash without boot.bin and cm.bin and post result
Absar_Global
Old 06-30-2018, 20:22   #12 (permalink)
Member: 282206
Thanks Meter: 102
hello
Page generated in 0.21302 seconds with 8 queries
