01-03-2017, 11:01 | #1 (permalink) |
No Life Poster Join Date: Oct 2006 Location: yaoundé (av kennedy)
Member: 361348 Status: Offline Thanks Meter: 635 | a510f reset frp To unlock NEW security type: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button and select 'New Unlock' for direct unlock. To unlock OLD security type: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Unlock' button and select 'Unlock' for direct unlock. To read security codes (all security types): 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Read codes' button to read security codes. To reset Pattern lock: 1. Power on phone in download mode (turn off phone, press vol.down + home + power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Reset Pattern Lock' button. To reset Google account activation or Samsung reactivation lock: 1. ADB must be activated in any way (you can flash sBoot from combination firmware, make sure, that you are not upgrade sBoot). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Select device in ADB settings. 4. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Reset FRP Selected model: SM-A510F Software version: 27.7 Waiting ADB device... Ok Reading phone info... Model: SM-A510F Android version: 6.0.1 Product code: SM-A510FEDATUR Phone version: A510FXXS3BPI2 PDA version: A510FXXS3BPIA CSC version: A510FOJV3BPI1 CSC country code: TURKEY CSC sales code: TUR HW version: MP 0.200 Phone SN: R58H909M1BW Chip name: EXYNOS7580 Modem board: SHANNON310 RF cal date: 20160903 IMEI: Bypass FRP... Ok For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.27.7 |
01-19-2017, 21:52 | #3 (permalink) |
Junior Member Join Date: Jul 2015
Member: 2421497 Status: Offline Thanks Meter: 0 | Waiting ADB device... Ok Reading phone info... Model: Android version: Product code: Phone version: PDA version: CSC version: CSC country code: CSC sales code: HW version: Phone SN: Chip name: Modem board: RF cal date: IMEI: Bypass FRP... Ok For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.27.7 after factory data reset nothing happen |
