Old 04-21-2017, 13:20   #16 (permalink)
uca
Member: 2495156
Thanks Meter: 3
Originally Posted by Velko View Post
Thanks Bro !
All is ok !
i turn it on by the combination that souma_k say but with which program i remove i try with z3x,chimera too but nothing it has frp stil
Old 04-21-2017, 14:06   #17 (permalink)
souma_k's Avatar
Member: 1933823
Thanks Meter: 563
Bro flash system from stock rom and it eill boot normally and you cand enter settings and factory reset (not from recovery)
IF YOU.LIKE WHAT I POST PRESS❤ THANKS BUTTON
The Following User Says Thank You to souma_k For This Useful Post:
Old 04-21-2017, 14:13   #18 (permalink)
uca
Member: 2495156
Thanks Meter: 3
thank you it woks you just earn a comment from me my friend
Old 04-21-2017, 14:16   #19 (permalink)
souma_k's Avatar
Member: 1933823
Thanks Meter: 563
Very good
B.R
The Following 2 Users Say Thank You to souma_k For This Useful Post:
Old 04-27-2017, 09:13   #20 (permalink)
tomi_no's Avatar
Member: 965
Thanks Meter: 25
Not work for me. I flash AdbEnabled_A510FXXU4_.tar, then Reset FRP ok.
Black screen, flash back A510FXXU4BQC1_A510FOXX4BQC1_ORX = still frp,
flash back only sboot and boot from stock = still frp, flash back stock without boot.img = restarts
please help
BR Tomi
Old 04-29-2017, 15:48   #21 (permalink)
Member: 244251
Thanks Meter: 5
this solution works for someone ?
Old 04-30-2017, 16:55   #22 (permalink)
galijus's Avatar
Member: 1131244
Sonork: 100.1596724
Thanks Meter: 337
I have the same problem.If I flash AdbEnabled_A510FXXU4_.tar,set go to black screen and enable adb,and I can bypass frp with z3x,but I cant reset from menu because do not see anything. Set can be alive only if I flash boot.img from stock rom,but after that frp is still on.
Please some clarification of procedure to reset frp with this method?
Old 04-30-2017, 17:06   #23 (permalink)
galijus's Avatar
Member: 1131244
Sonork: 100.1596724
Thanks Meter: 337
https://drive.google.com/file/d/0B4y...ew?usp=sharing
Can you please write exactly procedure to reset frp? What is needed to flash after reset frp with z3x,to enter setting to enable oem and reset? Because if I flash only system.img from stock,black screen,only when flash boot.img set is alive but frp is still on.
Old 04-30-2017, 17:18   #24 (permalink)
souma_k's Avatar
Member: 1933823
Thanks Meter: 563
https://mega.nz/#!1A501RjJ!8lZK5yLMu...cpPFy7jbK60D-4
This is combination flash this file and after that flash system from stock rom you should have adb activated and you can enter the settings to reset the phone to factory
Old 04-30-2017, 17:21   #25 (permalink)
galijus's Avatar
Member: 1131244
Sonork: 100.1596724
Thanks Meter: 337
I will try and post results.Thank you.
Old 04-30-2017, 19:49   #26 (permalink)
galijus's Avatar
Member: 1131244
Sonork: 100.1596724
Thanks Meter: 337
After flash combination file,can enter in menu,it is factory binary 5.1.1,have adb enabled but there is no option for oem unlock,with z3x bypass frp is done but after reset nothing is change.I flash only system.img from stock after,but adb became disabled and looks like nothing is change,frp is still on.All variants tried and can not repair this set.Any new suggestion is appreciated.
Operation: Reset FRP
Selected model: SM-A510F
Software version: 28.1
Waiting ADB device... Ok
Reading phone info...
Model: SM-A510F
Android version: 5.1.1
Product code: SM2A510FZWASER
Phone version: A510FXXU4AQC2
PDA version: FA51_A510FXXU4AQC1
CSC version:
CSC country code:
CSC sales code:
HW version: MP 0.200
Phone SN: RF8H40AFLPA
Chip name: EXYNOS7580
Modem board: SHANNON310
Security patch: 2015-11-01
RF cal date: 20160404
IMEI:
Bypass FRP... Ok
For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset'
Done with Samsung Tool PRO v.28.1
Old 04-30-2017, 19:50   #27 (permalink)
souma_k's Avatar
Member: 1933823
Thanks Meter: 563
Flash system only from stock fw use advanced mode
Originally Posted by galijus View Post
After flash combination file,can enter in menu,it is factory binary 5.1.1,have adb enabled but there is no option for oem unlock,with z3x bypass frp is done but after reset nothing is change.I flash only system.img from stock after,but adb became disabled and looks like nothing is change.All variants tried and can not repair this set.Any new suggestion is appreciated.
Model: SM-A510F
CSC version:
CSC country code:
CSC sales code:
IMEI:
Bypass FRP... Ok
Old 04-30-2017, 19:55   #28 (permalink)
galijus's Avatar
Member: 1131244
Sonork: 100.1596724
Thanks Meter: 337
From advanced mode I remove boot.img recovery.img userdata.img and remain only system.img from stock,after flash nothing changed.Frp is still on.D I need to flash something else?
Old 04-30-2017, 19:58   #29 (permalink)
souma_k's Avatar
Member: 1933823
Thanks Meter: 563
The phone starts in normal mode or boot loop?
Old 04-30-2017, 20:10   #30 (permalink)
galijus's Avatar
Member: 1131244
Sonork: 100.1596724
Thanks Meter: 337
not boot up,do not have logo,I can only switch to download mode and have to flash again to revive.It can boot only if I flash stock boot.img and after I have samsung logo and setup screen,with frp on.It have android is upgrading optimasing app 20 of 50,and counting,finish boot and set is on with frp on,asking acount,no adb.
Page generated in 0.87971 seconds with 7 queries
