06-12-2017, 07:46 | #1 (permalink) |
No Life Poster Join Date: Jan 2015
Member: 2325887 Status: Offline Thanks Meter: 134 | a510fd how to remove frp? 1. Choose correct flash file(s). 2. If you have PIT file chosen, then you must check 'Repartition' option. 3. Check flashing options if needed (Repartition, EFS clear, Boot update). 4. Power on phone in download mode (turn off phone, press vol.down + home + power). 5. Connect phone to PC with USB cable, install drivers if needed. 6. Press 'Flash' button. Operation: Flash Selected model: SM-A510FD Software version: 28.2 File analysis... Ok Total file size: 0xAF4B5CE8 (2804 Mb) Searching USB Flash interface... COM6 detected Setup connection... Ok Set PIT file... Ok Reading PIT from phone... Ok Sending sboot.bin... Ok Sending param.bin... Ok Sending cm.bin... Ok Sending boot.img... Ok Sending recovery.img... Ok Sending system.img... Ok Sending modem.bin... Ok Sending cache.img... Ok Sending hidden.img... Ok Flashing done (time - 00:03:40) Done with Samsung Tool PRO v.28.2 |
