A520f MSL unlock error Hello, I have error unlocking A520f with MSl... UNLOCK INSTRUÇÕES: This phoe can be unlocked with unique original MSL code only! 1. Phone must be powered on. 2. Type *#0808# and select 'DM+ACM+ADB'. 3. Run dialer and type *#0*# (service mode will apear). 4. Connect phone to USB cable, choose correct COM port in port settings. 5. Press 'Unlock' button. 6. Paste MSL code in new opened window and press 'OK'. Operation: Unlock Selected model: SM-A520F Software version: 28.2 Searching Samsung modem... detectado COM427 Obtendo informações do celular... OK Modelo: SM-A520F AP version: A520FXXU1AQC7 CSC version: A520FOXX1AQC7 CP version: A520FXXU1AQD3 Código do Produto: SM-A520FZKATPH Phone SN: R58J23D9BNB Número Exclusivo: CBJ101FBBFC1814 Reading IMEI... OK IMEI: 354XXXXXXXX8252 Reading SN... OK Phone SN: R58J23D9BN Enter MSL: 144B3F43143D12572B5703295DXXXXXX Bypass MSL... OK Desbloqueando... error Done with Samsung Tool PRO v.28.2 |
what is the knox count is it triggered ? |
add here a pic of download mode .. |
ODIN MODE DOWNLOAD SPEED: FAST PRODUCT NAME: SM-A520F CURRENT BINARY: Samsung Official SYSTEM STATUS: Official FRP LOCK: OFF Secure Download : Enabled CCIC = WARRANTY VOID: 1 ( 0X020c ) rP SWREV: B:1 K:0 S:0 DID = 0716cfa94cb8 |
WARRANTY VOID: 1 ( 0X020c ) above is the reason it ended up with an error At this stage msl will not help you to unlock it. Instead you must buy codes it will work if it not hard locked. |
Do you think FRP can solve the problem? |
U have a chance by flashing a combination firmware then try unlock its should work |
.. Quote:
flash and try unlock and tell us results |
