Old 05-17-2017, 15:40   #1 (permalink)
Member: 543573
Thanks Meter: 9
A520f MSL unlock error
Hello, I have error unlocking A520f with MSl...
UNLOCK INSTRUÇÕES:
This phoe can be unlocked with unique original MSL code only!
1. Phone must be powered on.
2. Type *#0808# and select 'DM+ACM+ADB'.
3. Run dialer and type *#0*# (service mode will apear).
4. Connect phone to USB cable, choose correct COM port in port settings.
5. Press 'Unlock' button.
6. Paste MSL code in new opened window and press 'OK'.
Operation: Unlock
Selected model: SM-A520F
Software version: 28.2
Searching Samsung modem... detectado COM427
Obtendo informações do celular... OK
Modelo: SM-A520F
AP version: A520FXXU1AQC7
CSC version: A520FOXX1AQC7
CP version: A520FXXU1AQD3
Código do Produto: SM-A520FZKATPH
Phone SN: R58J23D9BNB
Número Exclusivo: CBJ101FBBFC1814
Reading IMEI... OK
IMEI: 354XXXXXXXX8252
Reading SN... OK
Enter MSL: 144B3F43143D12572B5703295DXXXXXX
Bypass MSL... OK
Desbloqueando... error
Done with Samsung Tool PRO v.28.2
The Following User Says Thank You to manutencel For This Useful Post:
Old 05-17-2017, 18:02   #2 (permalink)
gayansuranga's Avatar
Member: 230004
Thanks Meter: 174
what is the knox count is it triggered ?
Old 05-17-2017, 18:46   #3 (permalink)
Member: 543573
Thanks Meter: 9
How can I look it, please?
Old 05-18-2017, 03:54   #4 (permalink)
Member: 230004
Thanks Meter: 174
add here a pic of download mode ..
Old 05-18-2017, 15:50   #5 (permalink)
Member: 543573
Thanks Meter: 9
ODIN MODE
DOWNLOAD SPEED: FAST
PRODUCT NAME: SM-A520F
CURRENT BINARY: Samsung Official
SYSTEM STATUS: Official
FRP LOCK: OFF
Secure Download : Enabled
CCIC =
WARRANTY VOID: 1 ( 0X020c )
rP SWREV: B:1 K:0 S:0
DID = 0716cfa94cb8
Old 05-19-2017, 03:31   #6 (permalink)
Member: 230004
Thanks Meter: 174
above is the reason it ended up with an error At this stage msl will not help you to unlock it. Instead you must buy codes it will work if it not hard locked.
Old 05-19-2017, 03:49   #7 (permalink)
CHANDARAKK's Avatar
Member: 930280
Thanks Meter: 1,183
UNLOCK INSTRUÇÕES:
Operation: Unlock
Modelo: SM-A520F
Reading IMEI... OK
Reading SN... OK
Bypass MSL... OK
u use usb or uart cable?
Old 05-19-2017, 21:04   #8 (permalink)
Member: 543573
Thanks Meter: 9
Do you think FRP can solve the problem?
Old 05-20-2017, 02:43   #9 (permalink)
Member: 230004
Thanks Meter: 174
I guess you already got your answer and frp has nothing to do with msl unlocking
The Following User Says Thank You to gayansuranga For This Useful Post:
Old 05-20-2017, 03:10   #10 (permalink)
CHANDARAKK's Avatar
Member: 930280
Thanks Meter: 1,183
am so confuse why knox trip can not on this model? so why i suuces on Sc-02h via MSL with knox trip please explain on this?
Old 05-20-2017, 11:41   #11 (permalink)
mr_basel_99's Avatar
Member: 2109940
Thanks Meter: 490
U have a chance by flashing a combination firmware then try unlock its should work
The Following User Says Thank You to mr_basel_99 For This Useful Post:
Old 05-20-2017, 12:56   #12 (permalink)
Cheater -Don't Deal with him-
Member: 1707492
Thanks Meter: 606
odin mode
download speed: Fast
product name: Sm-a520f
current binary: Samsung official
system status: Official
frp lock: Off
secure download : Enabled
ccic =
warranty void: 1 ( 0x020c )
rp swrev: B:1 k:0 s:0
did = 0716cfa94cb8
its not work msl :d
Old 05-21-2017, 13:16   #13 (permalink)
Member: 2109940
Thanks Meter: 490
Originally Posted by ikloveto View Post
means full flash? where can i find
eng-modem is a modem file from combination firmware
flash and try unlock and tell us results
Page generated in 0.32663 seconds with 8 queries
