06-27-2018, 08:15 | #1 (permalink) |
No Life Poster Join Date: May 2010 Location: india
Member: 1300517 Status: Offline Sonork: 100.1601031 Thanks Meter: 104 | a730f flashing problem (A8+) i am using this file A730FXXU2ARE2_OJM2ARE1 FLASH INSTRUCTIONS: 1. Choose correct flash file(s). 2. If you have PIT file chosen, then you must check 'Repartition' option. 3. Check flashing options if needed (Repartition, EFS clear, Boot update). 4. Power on the phone in download mode (turn off phone, press vol.down + home + power). 5. Connect the phone to PC with USB cable, install drivers if needed. 6. Press 'Flash' button. Operation: Flash Selected model: SM-A730F Software version: 32.7 File analysis... OK Total file size: 0x13A35E992 (5027 Mb) Searching USB Flash interface... COM5 detected Setup connection... OK Reading PIT from phone... OK Sending sboot.bin... error timeout Done with Samsung Tool PRO v.32.7 |
07-14-2018, 13:11 | #2 (permalink) |
Member: 1300517 Status: Offline Sonork: 100.1601031 Thanks Meter: 104 | any one help which problem FLASH INSTRUCTIONS: 1. Choose correct flash file(s). 2. If you have PIT file chosen, then you must check 'Repartition' option. 3. Check flashing options if needed (Repartition, EFS clear, Boot update). 4. Power on the phone in download mode (turn off phone, press vol.down + home + power). 5. Connect the phone to PC with USB cable, install drivers if needed. 6. Press 'Flash' button. Operation: Flash Selected model: SM-A730F Software version: 33.2 File analysis... OK Total file size: 0x13A1AC082 (5025 Mb) Searching USB Flash interface... COM5 detected Setup connection... OK Reading PIT from phone... error Done with Samsung Tool PRO v.33.2 |
07-14-2018, 13:47 | #3 (permalink) |
No Life Poster Join Date: Sep 2008 Location: Space Age: 49
Member: 861795 Status: Offline Thanks Meter: 1,275 | First try to flash phone with Odin3: Latest Odin3: Odin3_v3.13.1.zip If still fails Post recovery mode screenshot... |
07-14-2018, 16:09 | #5 (permalink) |
Member: 1300517 Status: Offline Sonork: 100.1601031 Thanks Meter: 104 | my lost try 3.12.7 odin3 <OSM> Enter CS for MD5.. <OSM> Check MD5.. Do not unplug the cable.. <OSM> Please wait.. <OSM> Checking MD5 finished Sucessfully.. <OSM> Leave CS.. <ID:0/005> Added!! <ID:0/005> Odin engine v(ID:3.1207).. <ID:0/005> File analysis.. <ID:0/005> SetupConnection.. <ID:0/005> Initialzation.. <ID:0/005> Set PIT file.. <ID:0/005> DO NOT TURN OFF TARGET!! <ID:0/005> FAIL! <ID:0/005> <ID:0/005> Re-Partition operation failed. <OSM> All threads completed. (succeed 0 / failed 1) <ID:0/005> Removed!! |
07-14-2018, 16:23 | #6 (permalink) |
Member: 1300517 Status: Offline Sonork: 100.1601031 Thanks Meter: 104 | 3.13.1 same problem <OSM> Checking MD5 finished Sucessfully.. <OSM> Leave CS.. <OSM> Enter CS for MD5.. <OSM> Check MD5.. Do not unplug the cable.. <OSM> Please wait.. <OSM> Checking MD5 finished Sucessfully.. <OSM> Leave CS.. <OSM> Enter CS for MD5.. <OSM> Check MD5.. Do not unplug the cable.. <OSM> Please wait.. <OSM> Checking MD5 finished Sucessfully.. <OSM> Leave CS.. <ID:0/005> Added!! <ID:0/005> Odin engine v(ID:3.1301).. <ID:0/005> File analysis.. <ID:0/005> skip file list for home binary <ID:0/005> param.bin <ID:0/005> userdata.img <ID:0/005> Home Binary Download <ID:0/005> Total Binary size: 3434 M <ID:0/005> SetupConnection.. <ID:0/005> Initialzation.. <ID:0/005> Get PIT for mapping.. <ID:0/005> <ID:0/005> There is no PIT partition. <OSM> All threads completed. (succeed 0 / failed 1) |
The Following User Says Thank You to G.G For This Useful Post: |
09-09-2018, 16:20 | #9 (permalink) |
No Life Poster Join Date: Dec 2008 Location: TURKEY Age: 46
Member: 917368 Status: Offline Sonork: 1615575 Thanks Meter: 147 | compatible region 8.0 firmware not flashing. phone always download mode. always flashing fail error ????? |
The Following User Says Thank You to Teknotel-GSM For This Useful Post: |
10-17-2019, 10:15 | #10 (permalink) |
Junior Member Join Date: Apr 2019 Location: lahore
Member: 2903540 Status: Offline Sonork: 100.1682502 Thanks Meter: 5 | A730F A8+ RMM prenormal first sorry for bad english..!!!! i have a730f U3 8.0 after flash phone goes to recovery and give error failed to mount efs....in download mode RMM is Prenormal any file i write phone give error only official file will flashed....please help Thanks in Advance Last edited by mohsin.butt; 10-17-2019 at 10:21. |
The Following User Says Thank You to mohsin.butt For This Useful Post: |
