03-03-2016, 11:09 | #1 (permalink) |
No Life Poster Join Date: May 2009
Member: 1024748 Status: Offline Thanks Meter: 53 | a800i after write cert problem 2nd imei BACKUP INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore. 6. Press 'Read CERT' button to read certificates or 'Write CERT' to restore. 7. Press 'Write NV DATA' if you need to restore NV backup. Operation: Write CERT Selected model: SM-A800I Software version: 24.5 Waiting ADB device... OK Reading phone info... Model: SM-A800I Android version: 5.1.1 Product code: Phone version: A800IXXU1AOJ1 PDA version: A800IXXU1AOJ1 CSC version: A800IOLB1AOJ1 CSC country code: MALAYSIA CSC sales code: XME HW version: Phone S/N: 00000000000 Modem board: SHANNON333 RF cal date: IMEI: Checking Super user right... true Initialization AT RIL... OK Checking for compatible phone and cert Phone KEY ID: 0838 Checking certificate file... OK KEY ID: 0838 Check version... OK Initializating zTool... OK Running zTool, please wait... OK Reading nv data... OK Checking NV data... OK Calculating... OK Writing nv data... OK Rebooting phone... OK Write CERT done Done with Samsung Tool PRO v.24.5 if i try 2nd time 2 imei goes 350000 if try 3rd first imei bk but 2nd imei still 350000 |
