04-27-2016, 15:47 | #1 (permalink) |
No Life Poster Join Date: Oct 2006 Location: yaoundé (av kennedy)
Member: 361348 Status: Offline Thanks Meter: 635 | A800I cert file read/writte BACKUP INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore. 6. Press 'Read CERT' button to read certificates or 'Write CERT' to restore. 7. Press 'Write NV DATA' if you need to restore NV backup. Operation: Read CERT Selected model: SM-A800I Software version: 25.2 Waiting ADB device... OK Reading phone info... Model: SM-A800I Android version: 5.1.1 Product code: SM-A800IZDEXSG Phone version: A800IXXU1AOJ1 PDA version: A800IXXU1AOJ1 CSC version: A800IOJV1AOJ1 CSC country code: UAE CSC sales code: XSG HW version: MP 0.200 Phone S/N: R58GB20ZLWN Modem board: SHANNON333 RF cal date: 20151119 IMEI: Checking Super user right... true Initializating zTool... OK Running zTool, please wait... Start... OK Init... OK Generate and check client proof... OK Verify proof by client... OK Reading data... OK Reading nv data... OK Checking NV data... OK Calculating... OK Certificate file saved to C:\Program Files (x86)\Z3X\Samsung\SamsungToolPRO\backup\Cert\SM-A800I_R58GB20ZLWN_354xxx1227097_35460xxx1227095_27-4-2016_16-32-30.cert Done with Samsung Tool PRO v.25.2 |
