11-15-2017, 07:10 | #4 (permalink) |
Junior Member Join Date: Mar 2017 Location: Nepal
Member: 2698004 Status: Offline Thanks Meter: 0 | UNLOCK INSTRUCTIONS: To reset Google account activation lock with UART cable: 1. Phone must be powered off 2. Connect the phone to UART cable. 3. Select correct COM port in port settings. 4. Press 'Reset FRP UFS' and follow the instructions in program. Operation: Reset FRP UFS Selected model: SM-A810F Selected port: COM3 USB Serial Port Software version: 29.8 Hold 'Vol down' and press 'POWER ON' for 2-3 seconds Checking phone at COM3 OK Phone detected, do not release 'Vol down' Reading data from phone... OK Release 'Vol down' now Comparing selected model... match (A810F) Setup connection... OK Reseting FRP... OK Rebooting phone... OK Reset FRP done Done with Samsung Tool PRO v.29.8 Same here Reset FRP done but not removed even after hard reset !!! |
11-15-2017, 11:25 | #7 (permalink) |
Member: 2698004 Status: Offline Thanks Meter: 0 | Hold 'Vol down' and press 'POWER ON' for 2-3 seconds Checking phone at COM3 OK Phone detected, do not release 'Vol down' Reading data from phone... OK Release 'Vol down' now Comparing selected model... match (A810F) Setup connection... OK Reseting FRP... OK Rebooting phone... OK Reset FRP done Done with Samsung Tool PRO v.29.5 Tried with 29.5 as well as inserted working sim but frp not removed |
11-15-2017, 12:14 | #8 (permalink) | |
Freak Poster Join Date: Jun 2016 Location: Home Age: 27
Member: 2583091 Status: Offline Thanks Meter: 413 | So the only solution left is combination + stock firmware Quote:
flash full combination file then flash the system,boot, recovery partition of the stock firmware and adb is enabled when the phone boots reset frp using adb on z3x. | |
09-15-2018, 14:41 | #13 (permalink) |
Junior Member Join Date: Mar 2016 Location: Peshawar
Member: 2547697 Status: Offline Sonork: 100.1662135 Thanks Meter: 4 | SM-A810F frp done 6.0.1 by z3x box You must activate ADB before reset FRP Yes Goto 'Terms and conditions' press 'NEXT' and 'AGREE' EULA Yes Waiting ADB device... OK Reading phone info... Model: SM-A810F Android version: 6.0.1 PDA version: A810FXXU1API7 CSC version: A810FOJV1API7 Phone version: A810FXXU1APIA Product code: SM-A810FZDDXSG CSC country code: UAE CSC sales code: XSG Phone SN: R58HC2WQS1Z IMEI: 352931081284523 HW version: MP 0.500 RF cal date: 20161214 Chip name: EXYNOS7420 Modem board: SHANNON333 Security patch: 2016-09-01 Boot Warranty bit: 0 Incorrect model selected. This may damage your phone. Continue? Yes Bypass FRP... OK For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.33.8 |
