Old 03-02-2010, 19:38   #1 (permalink)
LuisinhoCell's Avatar
Member: 264903
Sonork: 1584531
Thanks Meter: 3,350
Tutoring Unlock via Z3xBox
C270 / C276 - Unlock Procedure (Via Z3X-Box)
Remarks:
- Use RJ45 C450 or E210
Procedure:
- Select Model C270
- Select the COM PORT of the Box
- Click on the button DIRECT UNLOCK
- After the program show the message "Please, connect phone and press power button 3 seconds"
- Wait for the message Unlock
The Following 51 Users Say Thank You to LuisinhoCell For This Useful Post:
Old 03-02-2010, 19:57   #2 (permalink)
Member: 264903
Sonork: 1584531
Thanks Meter: 3,350
Unlock J165L Video
LuisinhoCell
The Following 39 Users Say Thank You to LuisinhoCell For This Useful Post:
Old 03-02-2010, 20:30   #3 (permalink)
Member: 264903
Sonork: 1584531
Thanks Meter: 3,350
Unlock E2210L
The Following 29 Users Say Thank You to LuisinhoCell For This Useful Post:
Old 03-03-2010, 20:12   #4 (permalink)
Member: 264903
Sonork: 1584531
Thanks Meter: 3,350
Unlock C506
select C520
Selected model: C520
Selected com port: COM93
Selected speed port: 460800
El teléfone deve estar Ligado!
Entering TestMode... OK
SW: C506VIGD5
Langpack: Not found langpack !
IMEI: 35515301393467
S/N: RS4P989805
HW-> MP 0.301
Senha do Teléfone: 00000000
Sum Flash: 1
Flash Prod ID: 0b0
Flash Device ID: 001d1111
Flash size: 16777216 Bytes
Flash sectors: 131 sectors
Bluetooth ID: BT não foi encontrado
Status OTP: OTP não presente
MSL DESACTIVADO - VERDADERO
Bloqueios está ativo
[NETLOCK]: Usar #0111*53128340# para desativar esse bloqueio
[SIMLOCK]: Usar #0141*00000000# para desativar esse bloqueio
Ler as informações - ok
Tempo Decorrido: 8 segundos, sw ver: 3.4.0030
Start unlock........
SW: C506VIGD5
NET e bloqueio do SIM - Desactivado
Alterando a senha no telefone -> 00000000
Desbloqueio - ok
Tempo Decorrido: 7 segundos, sw ver: 3.4.0030
The Following 18 Users Say Thank You to LuisinhoCell For This Useful Post:
Old 03-04-2010, 11:18   #5 (permalink)
billa2008's Avatar
Member: 687128
Thanks Meter: 261
how to flash procedure step by step
The Following 7 Users Say Thank You to billa2008 For This Useful Post:
Old 03-04-2010, 15:47   #6 (permalink)
Member: 264903
Sonork: 1584531
Thanks Meter: 3,350
- Select Model X150 - In the "Flash Files" select the BIN files, CLA
(Note: The files are compatible to the flash module HWK)
Click Red-Info
- click "Write Firmware".
- Wait for the process and ready, device successfully updated via Z3X.
LuisinhoCell
The Following 26 Users Say Thank You to LuisinhoCell For This Useful Post:
Old 03-05-2010, 10:43   #7 (permalink)
billa2008's Avatar
Member: 687128
Thanks Meter: 261
thank u very much
more explain flashing procedure samsung bro samsung
Old 03-05-2010, 19:25   #8 (permalink)
Member: 264903
Sonork: 1584531
Thanks Meter: 3,350
writing Imei the F250
LuisinhoCell
File Type: rar Write Imei F250 LuisinhoCell.part1.rar (381.8 KB, 2791 views)
File Type: rar Write Imei F250 LuisinhoCell.part2.rar (381.8 KB, 2266 views)
The Following 22 Users Say Thank You to LuisinhoCell For This Useful Post:
Old 03-05-2010, 21:33   #9 (permalink)
Member: 1143998
Thanks Meter: 14
A good screen, and very much hope that S5600 of the unlock screen, and let me understand the unlocking
The Following 5 Users Say Thank You to licheng For This Useful Post:
Old 03-05-2010, 21:45   #10 (permalink)
Member: 264903
Sonork: 1584531
Thanks Meter: 3,350
suffice it Drive correctly recognize
The Following 21 Users Say Thank You to LuisinhoCell For This Useful Post:
Old 03-05-2010, 22:06   #11 (permalink)
tynch000's Avatar
Member: 203536
Thanks Meter: 59
Here video for unlock s5600l with old version
http://www.4shared.com/file/14687985...80/s5600L.html
The Following 11 Users Say Thank You to tynch000 For This Useful Post:
Old 03-05-2010, 22:22   #12 (permalink)
Member: 264903
Sonork: 1584531
Thanks Meter: 3,350
Unlock i321n
-select the model E530
-Clique em Unlock
Last version on support: 2G tools v3.4.0030
Selected model: E530
SW: I321NVJFL1
IMEI: 35467501016323
S/N: Ler - falhou!
HW-> MP 0.300
Sum Flash: 1
Flash Prod ID: 0b0
Flash Device ID: 000b0000
Flash size: 33554432 Bytes
Flash sectors: 259 sectors
[NETLOCK]: Usar #0111*29034125# para desativar esse bloqueio
[SIMLOCK]: Usar #0141*96692676# para desativar esse bloqueio
Tempo Decorrido: 11 segundos, sw ver: 3.4.0030
SW: I321NVJFL1
Desbloqueio - ok
LuisinhoCell
The Following 30 Users Say Thank You to LuisinhoCell For This Useful Post:
Old 03-06-2010, 07:27   #13 (permalink)
Crazy Poster
Member: 154079
Thanks Meter: 9
brother, you wonderful.
Need more of this.Thanks
can you show us screen on how to unlock G800
The Following 4 Users Say Thank You to alolanre For This Useful Post:
Old 03-06-2010, 07:31   #14 (permalink)
himanshu taldar's Avatar
Member: 422762
Sonork: 100.1593904
Thanks Meter: 973
unlock s5233A step by step
by read code
use E210 combo cable and follow proceedure
when ask for modem insert usb cable and than when ask for uart port use rj45 connection
by pressing direct unlock
The Following 14 Users Say Thank You to himanshu taldar For This Useful Post:
Old 03-06-2010, 07:39   #15 (permalink)
Member: 422762
Sonork: 100.1593904
Thanks Meter: 973
Unlock E1117 & E1410
use E210 cable
select RJ45 com port & press DIRECt UNLOCK
The Following 7 Users Say Thank You to himanshu taldar For This Useful Post:
Nokia 6300 Vodafone-UK SW V57.20 -> UNLOCKED VIA OPERATOR CODE VIA KEYPAD! PROOF> Mr.Ultimate Nokia Base Band 5 ( BB-5 ) 1 07-02-2009 10:11
v3r unlock via ubl and via tp good mr manole. kikikokoki Ultima Box Light 0 04-08-2009 07:40
v3r unlock via ubl via tp unlock kikikokoki Ultima Box Light 1 03-15-2009 23:00
★★★ BEST & Fastest BlackBerry Unlock VIA USB + HOT Services VIA IMEI ★★★ E_H Main Sales Section 0 12-26-2008 19:08
Page generated in 0.29871 seconds with 10 queries
