10-21-2016, 08:27 | #1 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Am In Wealth Always!
Member: 576282 Status: Offline Thanks Meter: 145 | A927 unlocking is not working, plz how to do that? Flashing logs; FLASH INSTRUCTIONS: 1. Choose correct flash file(s). 2. Check flashing options if needed (Auto reboot to flash mode, Boot update). 3. Power on phone in download mode (turn off phone, hold vol.down + Camera + Power). 4. Connect phone to PC with USB cable, install drivers if needed. 5. Press 'Flash' button. Operation: Flash Selected model: SGH-A927 Software version: 20.5 Searching Samsung USB flash interface... detected COM8 CPU type: MSM6275/MSM6280/MSM6290 (03) Flash page size: x0800 Flash page count: x0040 Erasing QcSblHD_cfgdata.mbn... OK Sending QcSblHD_cfgdata.mbn... OK Erasing MIBIB1.mbn... OK Sending MIBIB1.mbn... OK Erasing MIBIB2.mbn... OK Sending MIBIB2.mbn... OK Erasing QcSbl.mbn... OK Sending QcSbl.mbn... OK Erasing OEMSbl.mbn... OK Sending OEMSbl.mbn... OK Flashing BOOT files done (time - 00:00:04) Wait, reset... Erasing AMSS... OK Sending AMSS... OK Erasing RSRC1... OK Sending RSRC1... OK Erasing RSRC2... OK Sending RSRC2... OK Erasing FFS... OK Formating FFS... OK Sending FFS... OK Flashing done (time - 00:05:52) Done with Samsung Tool v.20.5 Unlocking logs; UNLOCK INSTRUCTIONS: Read codes only USB cable : 1. Phone must be powered on. 2. Type *#782872# to switch phone to Qualcomm USB mode, (after operations you can enter *#726872# to switch back to Samsung USB mode.) 3. Connect USB cable, install drivers. 4. Select diagnostic port in port settings. 5. Enter *#7465625# (phone must display locks status). 6. Press 'Read codes' to read security codes. Operation: Read Codes Selected model: SGH-A927 Selected port: COM15 Qualcomm HS-USB Diagnostics 9002, Software version: 20.5 Reading phone info... OK Model: SGH-A927 Country code: ¹Ì±¹/ATT Cal date: 2010-07-12 Factory SW: UCJF5 Unique number: 55290001502295 Memory phone: K5R2G1GACC(A927)S Phone S/N: RPIBC50691 Reading IMEI... OK IMEI: 353602045615883 Reading software version... OK Phone version: A927UCJF5 Searching sysinfo... not found Done with Samsung Tool v.20.5 please how will I unlock it? Thanks! |
10-22-2016, 04:47 | #2 (permalink) | |
Member: 576282 Status: Offline Thanks Meter: 145 | Quote:
please somebody help me out about this na? | |
10-27-2016, 07:57 | #4 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Africa.uganda
Member: 562975 Status: Offline Sonork: better tomorow Thanks Meter: 247 | SGH-A927 unlocking failed. i need to unlock his phone but which version of softwear do i have to use? UNLOCK INSTRUCTIONS: Read codes only USB cable : 1. Phone must be powered on. 2. Type *#782872# to switch phone to Qualcomm USB mode, (after operations you can enter *#726872# to switch back to Samsung USB mode.) 3. Connect USB cable, install drivers. 4. Select diagnostic port in port settings. 5. Enter *#7465625# (phone must display locks status). 6. Press 'Read codes' to read security codes. Operation: Read Codes Selected model: SGH-A927 Selected port: COM75 Samsung HS-USB Diagnostics 9002 Software version: 27.0 Reading phone info... ok Model: SGH-A927 Country code: ¹Ì±¹/ATT Cal date: 2010-07-12 Factory SW: UCJF5 Unique number: 60990000656703 Memory phone: K5R2G1GACC(A927)S Phone SN: R2AB741790 Reading IMEI... ok IMEI: 351879048249397 Reading software version... ok Phone version: A927UCJF5 Searching sysinfo... not found Done with Samsung Tool PRO v.27.0 |
