about unlock E2230 by Z3X i use z3x box unlock the samsung E2230 ,this is my log Selected model: E2230 Selected com port: COM141 Selected speed port: 921600 Phone must be OFF Press * and connect phone by USB cable Connecting to Device... OK Sending preloader ... OK Sending loader ... OK Damping ... OK Erasing ... OK Writing ... OK After power on phone - connect to UART cable Deactivate MSL - fail Read info - fail Elapsed time: 40 second, sw ver: 3.5.0035 I search many thread about this problem , but i can't find way to slove it someone say use the 2g tool 3.5.0022 can prefect do it , but i can't download the setup file of 3.5.0022, who can help me? |
Which cable are you using. Br. Vijendra Saini. |
i use E210 + cable ,because E210 cable can’t connect the phone |
best choise E2330 use cable usb E210 and rj45 J750 |
but E210 can't use Z3X connect the phone |
At the moment the HWK is best support for this E2230 model to do any kind of operation flashing/unlocking or repairing IMEI. i just done a fone after tired on Z3X. B,R;) |
@ALL just don't bother with other tools : use ZX3 select E2330 , prepare regular USB data cable press safe info when program ask, press * on phone and insert USB data Cable on any computer usb port seat and wait... and - job done ! Selected model: E2230 Selected com port: COM22 Selected speed port: 921600 Phone must be OFF Press * and connect phone by USB cable Connecting to Device... OK Sending preloader ... OK Sending loader ... OK read device - fail! safe read info - fail Elapsed time: 84 second, sw ver: 3.5.0037 ------------------------------------------------------------------------------- Selected model: E2330 Selected com port: COM22 Selected speed port: 921600 Phone must be OFF Press * and connect phone by USB cable Connecting to Device... OK Sending preloader ... OK Sending loader ... OK Damping ... OK Calculated code please wait... Decrypted time: 30 sec This is zone 0 [PCK]:Enter this without sim #0141*00000000# this is sim lock [NCK]:Enter this without sim #0111*47022710# this is net lock [SCK]:Enter this without sim #0121*00000000# this is CP lock [SPCK]:Enter this without sim #0133*00000000# this is SP lock [MCK]:Enter this without sim #0199*12145964# this is Master(freeze) code safe read info - ok Elapsed time: 123 second, sw ver: 3.5.0037 ------------------------------------------------------------------------------- |
Unlock E2230 problem I cannot unlock E2230 , tried many things, unlock choosing E2230, then imei got 000000000000000 i can repair this Z3x that's no problem. i tried unlock / read with choosing E2330, also not working, i tried full reset en than unlock or read codes , not working.. i flashed the E2230 with Z3x, no problem i tried to unlock or read E2230 not working. i use different cable's on this moment phone is still locked..... :confused: |
did phone connect or not? And, do not press raed code / direct unlock : must press SAFE INFO in flash window tab |
Very easy to unlock Samsung E2230 , dont need special cable or special anything With classic Samsung e210 combo cable Choose please E2530 then read info (codes) then you get code :) Selected model: E2530 Selected com port: COM4 Selected speed port: 921600 Phone must be OFF Press * and connect phone by cable Connecting to Device... OK Wait for decrypted code... OK Decrypted time: 76 sec [PCK]:#0141*00000000# [NCK]:#0111*78969893# [SCK]:#0121*00000000# [SPCK]:#0133*21183620# [MCK]:#0199*63577825# Read info - ok Elapsed time: 105 second, sw ver: 3.5.0022 ------------------------------------------------------------------------------- :D:D:D |
i gost this error: Selected model: E2530 Selected com port: COM14 Selected speed port: 115200 Phone must be OFF Press * and connect phone by USB cable Connecting to Device... OK Sending preloader ... OK Sending loader ... OK Damping ... OK Not found code hash - fail safe read info - fail Elapsed time: 88 second, sw ver: 3.5.0038 this is last vertion. it was suppose to work better than previous vertion PLease solve this |
Selected model: E2530 Selected com port: COM1 Selected speed port: 921600 Phone must be OFF Press * and connect phone by cable Connecting to Device... OK Wait for decrypted code... OK Decrypted time: 56 sec [PCK]:#0141*00000000# [NCK]:#0111*81848631# [SCK]:#0121*00000000# [SPCK]:#0133*63587459# [MCK]:#0199*78266284# Read info - ok Elapsed time: 74 second, sw ver: 3.5.0022 ------------------------------------------------------------------------------ Others vertions have bug to be fixed by z3x team. |
Unlock E2230 I tried all methods to unlock but none worked. This is was the error that i had: Selected model: E2230 Selected com port: COM4 Selected speed port: 921600 Phone must be OFF Press * and connect phone by USB cable Connecting to Device... OK Sending preloader ... OK Sending loader ... OK Damping ... OK Erasing ... OK Writing ... OK After power on phone - connect to UART cable Deactivate MSL - fail Read info - fail Elapsed time: 27 second, sw ver: 3.5.0038 But I discovered a method that helped me to unlock this phone model. I select the model E2330, i use a normal USB cable, click on safe info and is done. This is my proof: Selected model: E2330 Selected com port: COM4 Selected speed port: 921600 Phone must be OFF Press * and connect phone by USB cable Connecting to Device... OK Sending preloader ... OK Sending loader ... OK Damping ... OK Calculated code please wait... Decrypted time: 27 sec This is zone 0 [PCK]:Enter this without sim #0141*00000000# this is sim lock [NCK]:Enter this without sim #0111*29978477# this is net lock [SCK]:Enter this without sim #0121*00000000# this is CP lock [SPCK]:Enter this without sim #0133*00000000# this is SP lock [MCK]:Enter this without sim #0199*31327165# this is Master(freeze) code safe read info - ok Elapsed time: 119 second, sw ver: 3.5.0038 |
Selected model: E2530 Selected com port: COM3 Selected speed port: 921600 Phone must be OFF Press * and connect phone by USB cable Connecting to Device... OK Sending preloader ... OK Sending loader ... OK Damping ... OK Erasing ... OK Writing ... OK After power on phone - connect to UART cable Timeout Deactivate MSL - fail Unlock - fail Elapsed time: 74 second, sw ver: 3.5.0038 ------------------------------------------------------------------------------- Selected model: E2530 Selected com port: COM3 Selected speed port: 921600 Phone must be OFF Press * and connect phone by USB cable Connecting to Device... OK Sending preloader ... OK Sending loader ... OK Damping ... OK Erasing ... OK Writing ... OK After power on phone - connect to UART cable Timeout Deactivate MSL - fail Unlock - fail Elapsed time: 75 second, sw ver: 3.5.0038 ------------------------------------------------------------------------------- Selected model: E2530 Selected com port: COM3 Selected speed port: 921600 Phone must be OFF Press * and connect phone by USB cable Connecting to Device... OK Sending preloader ... OK Sending loader ... OK Damping ... OK Erasing ... OK Writing ... OK After power on phone - connect to UART cable Timeout Deactivate MSL - fail Unlock - fail Elapsed time: 82 second, sw ver: 3.5.0038 ------------------------------------------------------------------------------- Selected model: E2530 Selected com port: COM3 Selected speed port: 921600 Phone must be OFF Press * and connect phone by USB cable Connecting to Device... OK Sending preloader ... OK Sending loader ... OK Damping ... OK Damping ... OK Calculated code please wait... Decrypted time: 24 sec This is zone 0 [PCK]:Enter this without sim #0141*00000000# this is sim lock [NCK]:Enter this without sim #0111*24479375# this is net lock [SCK]:Enter this without sim #0121*00000000# this is CP lock [SPCK]:Enter this without sim #0133*00000000# this is SP lock [MCK]:Enter this without sim #0199*11990559# this is Master(freeze) code This is zone 1 [PCK]:Enter this without sim #0141*00000000# this is sim lock [NCK]:Enter this without sim #0111*24479375# this is net lock [SCK]:Enter this without sim #0121*00000000# this is CP lock [SPCK]:Enter this without sim #0133*00000000# this is SP lock [MCK]:Enter this without sim #0199*11990559# this is Master(freeze) code This is zone 2 [PCK]:Enter this without sim #0141*00000000# this is sim lock [NCK]:Enter this without sim #0111*24479375# this is net lock [SCK]:Enter this without sim #0121*00000000# this is CP lock [SPCK]:Enter this without sim #0133*00000000# this is SP lock [MCK]:Enter this without sim #0199*11990559# this is Master(freeze) code safe read info - ok Elapsed time: 195 second, sw ver: 3.5.0038 ------------------------------------------------------------------------------- |
