Old 03-17-2012, 08:47   #1 (permalink)
Member: 1679901
about unlock E2230 by Z3X
i use z3x box unlock the samsung E2230 ,this is my log
Selected model: E2230
Selected com port: COM141
Selected speed port: 921600
Phone must be OFF
Press * and connect phone by USB cable
Connecting to Device... OK
Sending preloader ... OK
Sending loader ... OK
Damping ... OK
Erasing ... OK
Writing ... OK
After power on phone - connect to UART cable
Deactivate MSL - fail
Read info - fail
Elapsed time: 40 second, sw ver: 3.5.0035
I search many thread about this problem , but i can't find way to slove it
someone say use the 2g tool 3.5.0022 can prefect do it , but i can't download the setup file of 3.5.0022, who can help me?
Old 03-17-2012, 20:43   #2 (permalink)
Vijendra Saini's Avatar
Member: 398557
Sonork: 100.1578489
Thanks Meter: 1,513
Which cable are you using.
Br.
Vijendra Saini.
Old 03-18-2012, 04:39   #3 (permalink)
Member: 1679901
i use E210 + cable ,because E210 cable can’t connect the phone
Old 03-18-2012, 05:02   #4 (permalink)
jmr
Member: 614683
Sonork: 100.1605379
Thanks Meter: 343
best choise E2330 use cable usb E210 and rj45 J750
Old 03-18-2012, 08:16   #5 (permalink)
Member: 1679901
but E210 can't use Z3X connect the phone
Old 05-29-2012, 16:48   #6 (permalink)
Registered User
Member: 437195
Thanks Meter: 1,729
At the moment the HWK is best support for this E2230 model to do any kind of operation flashing/unlocking or repairing IMEI.
i just done a fone after tired on Z3X.
B,R
Old 05-29-2012, 16:56   #7 (permalink)
sidrasystems1's Avatar
Member: 1398382
Thanks Meter: 57
Phone must be OFF
Damping ... OK
Erasing ... OK
Writing ... OK
Read info - fail
i have done many set cont me on yahoo messenger - yunshaikh786
Old 06-14-2012, 13:40   #8 (permalink)
Crumarix1's Avatar
Member: 84300
Thanks Meter: 61
@ALL
just don't bother with other tools :
use ZX3
select E2330 , prepare regular USB data cable
press safe info
when program ask, press * on phone and insert USB data Cable on any computer usb port
seat and wait...
and - job done !
Selected com port: COM22
Phone must be OFF
read device - fail!
safe read info - fail
Elapsed time: 84 second, sw ver: 3.5.0037
Selected model: E2330
Phone must be OFF
Damping ... OK
Calculated code please wait...
Decrypted time: 30 sec
This is zone 0
[PCK]:Enter this without sim #0141*00000000# this is sim lock
[NCK]:Enter this without sim #0111*47022710# this is net lock
[SCK]:Enter this without sim #0121*00000000# this is CP lock
[SPCK]:Enter this without sim #0133*00000000# this is SP lock
[MCK]:Enter this without sim #0199*12145964# this is Master(freeze) code
safe read info - ok
Elapsed time: 123 second, sw ver: 3.5.0037
Old 06-21-2012, 12:22   #9 (permalink)
Member: 63646
Sonork: 1670920:45069
Thanks Meter: 11
Unlock E2230 problem
I cannot unlock E2230 ,
tried many things,
unlock choosing E2230, then imei got 000000000000000
i can repair this Z3x that's no problem.
i tried unlock / read with choosing E2330, also not working,
i tried full reset en than unlock or read codes , not working..
i flashed the E2230 with Z3x, no problem
i tried to unlock or read E2230 not working.
i use different cable's on this moment phone is still locked.....
Old 06-27-2012, 11:16   #10 (permalink)
Crumarix1's Avatar
Member: 84300
Thanks Meter: 61
did phone connect or not?
And, do not press raed code / direct unlock :
must press SAFE INFO in flash window tab
Old 06-27-2012, 11:19   #11 (permalink)
Special@gsm's Avatar
Member: 4003
Sonork: 100.111841
Thanks Meter: 38
Very easy to unlock Samsung E2230 , dont need special cable or special anything
With classic Samsung e210 combo cable
Choose please E2530 then read info (codes)
then you get code
Selected model: E2530
Selected com port: COM4
Phone must be OFF
Press * and connect phone by cable
Wait for decrypted code... OK
Decrypted time: 76 sec
[PCK]:#0141*00000000#
[NCK]:#0111*78969893#
[SCK]:#0121*00000000#
[SPCK]:#0133*21183620#
[MCK]:#0199*63577825#
Read info - ok
Elapsed time: 105 second, sw ver: 3.5.0022
Old 07-24-2012, 22:18   #12 (permalink)
Member: 4596
Sonork: ssemmedo
Thanks Meter: 3
i gost this error:
Selected speed port: 115200
Phone must be OFF
Damping ... OK
Not found code hash - fail
Elapsed time: 88 second, sw ver: 3.5.0038
this is last vertion. it was suppose to work better than previous vertion
PLease solve this
Old 07-24-2012, 23:01   #13 (permalink)
Member: 4596
Sonork: ssemmedo
Thanks Meter: 3
Phone must be OFF
Decrypted time: 56 sec
[NCK]:#0111*81848631#
[SPCK]:#0133*63587459#
[MCK]:#0199*78266284#
Read info - ok
Elapsed time: 74 second, sw ver: 3.5.0022
Others vertions have bug to be fixed by z3x team.
Old 09-06-2012, 10:26   #14 (permalink)
Member: 1740072
Sonork: 100.1638230
Thanks Meter: 9
Unlock E2230
I tried all methods to unlock but none worked. This is was the error that i had:
Phone must be OFF
Damping ... OK
Erasing ... OK
Writing ... OK
Read info - fail
Elapsed time: 27 second, sw ver: 3.5.0038
But I discovered a method that helped me to unlock this phone model. I select the model E2330, i use a normal USB cable, click on safe info and is done. This is my proof:
Phone must be OFF
Damping ... OK
Decrypted time: 27 sec
This is zone 0
[NCK]:Enter this without sim #0111*29978477# this is net lock
[MCK]:Enter this without sim #0199*31327165# this is Master(freeze) code
safe read info - ok
Elapsed time: 119 second, sw ver: 3.5.0038
The Following 2 Users Say Thank You to sorelpc For This Useful Post:
Old 09-08-2012, 08:38   #15 (permalink)
Member: 1524022
Sonork: 100.1608738
Thanks Meter: 25
Selected com port: COM3
Phone must be OFF
Damping ... OK
Erasing ... OK
Writing ... OK
Timeout
Unlock - fail
Elapsed time: 74 second, sw ver: 3.5.0038
Phone must be OFF
Damping ... OK
Erasing ... OK
Writing ... OK
Timeout
Unlock - fail
Elapsed time: 75 second, sw ver: 3.5.0038
Phone must be OFF
Damping ... OK
Erasing ... OK
Writing ... OK
Timeout
Unlock - fail
Elapsed time: 82 second, sw ver: 3.5.0038
Phone must be OFF
Damping ... OK
Damping ... OK
Decrypted time: 24 sec
This is zone 0
[NCK]:Enter this without sim #0111*24479375# this is net lock
[MCK]:Enter this without sim #0199*11990559# this is Master(freeze) code
This is zone 1
This is zone 2
safe read info - ok
Elapsed time: 195 second, sw ver: 3.5.0038
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
$50 Reward for unlocking my 6150!!! TheDon Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 5 03-23-2015 15:21
need software for 5161 by cable mln2000 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 08-29-2010 21:17
Question about 51xx/61xx Comic Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 07-07-1999 00:47
Page generated in 0.60595 seconds with 8 queries
