05-17-2013, 01:09 | #1 (permalink) |
Junior Member Join Date: Apr 2011
Member: 1555702 Status: Offline Thanks Meter: 1 | Ace II - I8160P Bypass MSL error tried to repair IMEI of I8160P by switching to UART cable C3300K but got: Code: Selected model: I8160P Selected port: Selected port speed: 115200 Port not selected Done with Samsung Tool v.14.4 Selected model: I8160P Selected port: COM1 USB Serial Port Selected port speed: 115200 Phone not found Done with Samsung Tool v.14.4 Selected model: I8160P Selected port: COM1 USB Serial Port Selected port speed: 115200 Reading phone info... Model: GT-I8160P Android version: 2.3.6 Product code: Unknown Phone version: Unknown PDA version: I8160PXXLK2 CSC version: I8160PDBTLK2 IMEI: Unknown Checking Super user right... true Reading data from phone... OK Now connect phone to UART cable Checking phone at COM1 OK Bypass MSL... error Done with Samsung Tool v.14.4 Regards, onkeltom Last edited by onkeltom; 05-17-2013 at 01:14. |
05-17-2013, 05:40 | #2 (permalink) |
No Life Poster Join Date: May 2001 Location: Bulgaria Age: 56
Member: 4627 Status: Online Sonork: 57528:debeliamark Thanks Meter: 1,034 | To unlock Galaxy Ace 2 ( even i8160 or i8160p ) you need to root this phone manualy first. There a few ways, but in all cases need to upload a some update package via SD card. A good guide is writen here. Just follow the steps and after rooting - unlock via Z3x. WBR, DebeliaMark, BG |
05-17-2013, 19:35 | #4 (permalink) |
Member: 1555702 Status: Offline Thanks Meter: 1 | Hi, doesn't work for me. Manually rooted, but still: Bypass MSL... error Code: Selected model: I8160P Selected port: COM1 USB Serial Port Selected port speed: 115200 File analysis... OK Total file size: 0x26FCC15D Searching USB Flash Interface... detected COM20 Setup connection... OK Reading PIT from phone... OK Saved to C:\Program Files (x86)\Z3X\Samsung\SamsungTool\Pit\I8160P_17-5-2013_18-24-35.pit Sending system.img.md5... OK Sending cache.img.md5... OK Flashing done (time - 00:02:37) Done with Samsung Tool v.14.4 Selected model: I8160P Selected port: COM1 USB Serial Port Selected port speed: 115200 Reading phone info... Model: GT-I8160P Android version: 2.3.6 Product code: Unknown Phone version: Unknown PDA version: I8160PXXLE6 CSC version: Unknown IMEI: Unknown Checking Super user right... true Reading data from phone... OK Now connect phone to UART cable Checking phone at COM1 OK Bypass MSL... error Done with Samsung Tool v.14.4 Selected model: I8160P Selected port: COM1 USB Serial Port Selected port speed: 115200 File analysis... OK Total file size: 0x26FCC15D Searching USB Flash Interface... detected COM20 Setup connection... OK Reading PIT from phone... OK Saved to C:\Program Files (x86)\Z3X\Samsung\SamsungTool\Pit\I8160P_17-5-2013_18-33-0.pit Sending system.img.md5... OK Sending cache.img.md5... OK Flashing done (time - 00:02:33) Done with Samsung Tool v.14.4 Selected model: I8160P Selected port: COM1 USB Serial Port Selected port speed: 115200 File analysis... OK Total file size: 0x2992EF86 Searching USB Flash Interface... detected COM21 Setup connection... OK Reading PIT from phone... OK Saved to C:\Program Files (x86)\Z3X\Samsung\SamsungTool\Pit\I8160P_17-5-2013_19-52-1.pit Sending cache.img.md5... OK Sending hidden.img.md5... OK Sending kernel.bin.md5... OK Sending modem.bin.md5... Error Done with Samsung Tool v.14.4 Selected model: I9100 Selected port: COM1 USB Serial Port Selected port speed: 115200 File analysis... OK Total file size: 0x249DB180 Searching USB Flash Interface... detected COM22 Setup connection... OK Reading PIT from phone... OK Saved to C:\Program Files (x86)\Z3X\Samsung\SamsungTool\Pit\I9100_17-5-2013_20-4-45.pit Sending modem.bin... Error Done with Samsung Tool v.14.4 Selected model: I9100 Selected port: COM1 USB Serial Port Selected port speed: 115200 File analysis... OK Total file size: 0x249DB180 Searching USB Flash Interface... not found Done with Samsung Tool v.14.4 Selected model: I9100 Selected port: COM1 USB Serial Port Selected port speed: 115200 File analysis... OK Total file size: 0x249DB180 Searching USB Flash Interface... not found Done with Samsung Tool v.14.4 Selected model: I9100 Selected port: COM1 USB Serial Port Selected port speed: 115200 File analysis... OK Total file size: 0x249DB180 Searching USB Flash Interface... detected COM22 Setup connection... OK Set PIT file... OK Reading PIT from phone... OK Saved to C:\Program Files (x86)\Z3X\Samsung\SamsungTool\Pit\I9100_17-5-2013_20-5-56.pit Sending cache.img... OK Sending factoryfs.img... OK Sending MLO... Error Done with Samsung Tool v.14.4 Selected model: I9100 Selected port: COM1 USB Serial Port Selected port speed: 115200 File analysis... OK Total file size: 0x249DB180 Searching USB Flash Interface... not found Done with Samsung Tool v.14.4 Selected model: I9100 Selected port: COM1 USB Serial Port Selected port speed: 115200 File analysis... OK Total file size: 0x249DB180 Searching USB Flash Interface... detected COM22 Setup connection... OK Set PIT file... OK Reading PIT from phone... OK Saved to C:\Program Files (x86)\Z3X\Samsung\SamsungTool\Pit\I9100_17-5-2013_20-9-18.pit Sending cache.img... OK Sending factoryfs.img... OK Sending MLO... Error Done with Samsung Tool v.14.4 Selected model: I8160P Selected port: COM1 USB Serial Port Selected port speed: 115200 File analysis... OK Total file size: 0x26FCC15D Searching USB Flash Interface... detected COM21 Setup connection... OK Reading PIT from phone... OK Saved to C:\Program Files (x86)\Z3X\Samsung\SamsungTool\Pit\I8160P_17-5-2013_20-21-24.pit Sending system.img.md5... OK Sending cache.img.md5... OK Flashing done (time - 00:02:38) Done with Samsung Tool v.14.4 Selected model: I8160P Selected port: COM1 USB Serial Port Selected port speed: 115200 Reading phone info... Model: GT-I8160P Android version: 2.3.6 Product code: Unknown Phone version: Unknown PDA version: I8160PXXLE6 CSC version: I8160PDBTLE5 IMEI: Unknown Checking Super user right... true Reading data from phone... OK Now connect phone to UART cable Checking phone at COM1 OK Bypass MSL... error Done with Samsung Tool v.14.4 Selected model: I8160P Selected port: COM1 USB Serial Port Selected port speed: 115200 Reading phone info... Model: GT-I8160P Android version: 2.3.6 Product code: Unknown Phone version: Unknown PDA version: I8160PXXLE6 CSC version: I8160PDBTLE5 IMEI: Unknown Checking Super user right... true Reading data from phone... OK Now connect phone to UART cable Checking phone at COM1 OK Bypass MSL... error Done with Samsung Tool v.14.4 Regards, onkeltom |
05-19-2013, 20:59 | #6 (permalink) |
Member: 1555702 Status: Offline Thanks Meter: 1 | Hi, I already switched to modem. I figured out: After resurrecting I8160P with Riff Box the Splash Screen and Download Mode Screen show I8160. When flashing I8160P firmware (2.3.6 or 4.1.2) there is no IMEI and therefore no network and no way to repair IMEI via Z3X Box. When flashing I8160 firmware *#06# shows IMEI and phone is registered in network. This behaviour is reproducible. Regards, onkeltom Last edited by onkeltom; 05-19-2013 at 21:06. |
05-24-2013, 12:55 | #7 (permalink) |
Junior Member Join Date: May 2013
Member: 1945059 Status: Offline Thanks Meter: 0 | Hello, I have done a software upgrade vfrom GB 2.3.6 (XEF) to JB 4.1.2 (DBT) including a re partition by a pit file. Everything works, but the Mobile is now seen by KIES as a German one (DBT) an even after downgrading to GB (XEF) the software works, but Kies just identify it as an German Variant. So do I need pit file need a pit file for the GT-I8160P (NFC), France (XEF), to reset back all to France version (which was the original one?) Where can I get it? During the flashing process i have used the pit file of GT-I8160 (without "P") (that one, that can be found in the net, named: GT-I8160_EUR_XX_4G.pit) Is there any difference in the pitfiles between the P or non P variants? Thanks! |
