05-27-2013, 16:19 | #1 (permalink) |
No Life Poster Join Date: Aug 2012
Member: 1792561 Status: Offline Thanks Meter: 78 | After Flash i9100 come yellow tringle mark need help After Flash i9100 come yellow tringle mark down of samsung i9100 set is not power on. Code: Selected model: I9100 Selected port: Selected port speed: 115200 File analysis... OK Total file size: 0x386AC024 Searching USB Flash Interface... detected COM16 Setup connection... OK Reading PIT from phone... OK Saved to C:\Program Files\Z3X\Samsung\SamsungTool\Pit\I9100_27-5-2013_20-43-55.pit Sending boot.bin... OK Sending data.img... OK Sending factoryfs.img... OK Sending hidden.img... OK Sending param.lfs... OK Sending Sbl.bin... OK Sending zImage... OK Sending modem.bin... OK Sending cache.img... OK Flashing done (time - 00:02:56) Done with Samsung Tool v.14.5 |
05-27-2013, 21:41 | #3 (permalink) |
No Life Poster Join Date: Feb 2008 Location: Algeria
Member: 695274 Status: Offline Thanks Meter: 814 | 1-for the yelow triangle restor the original karnel 2- for: stuck in sumsung logo ...many i9100 need to wipe user data after flash of cours if you can to entre in recovry mode and if you c'ant try with other firmware |
05-28-2013, 06:08 | #5 (permalink) | ||
Product Supporter Join Date: Sep 2006 Location: Kerala-India Age: 46
Member: 351924 Status: Offline Thanks Meter: 12,469 | flash file problem flash this firmware Quote:
The Following 2 Users Say Thank You to SHIJILFONOTLY For This Useful Post: |
05-28-2013, 14:37 | #7 (permalink) |
Registered User Join Date: Mar 2013 Location: pakistan
Member: 1901604 Status: Offline Sonork: 100.1622736 Thanks Meter: 72 | www.**************** here you can download all samsung firmware |
05-28-2013, 15:52 | #9 (permalink) |
Freak Poster Join Date: Sep 2007 Location: India
Member: 583492 Status: Offline Thanks Meter: 125 | download triangle away from here and install Download TAv2 apk |
05-28-2013, 18:21 | #11 (permalink) |
Member: 1792561 Status: Offline Thanks Meter: 78 | i flash with u1_02_20110310_emmc_EXT4.pit I9100XWLPW_I9100XSALP6_I9100XXLQ6_HOME.tar but same stuck on samsung and yellow tringle i repair deadboot also sucessful. it can't be enter also recovery mode. |
06-08-2013, 17:29 | #15 (permalink) |
Freak Poster Join Date: May 2007 Location: PATTAMUNDAI
Member: 508774 Status: Offline Sonork: 100.1590207 Thanks Meter: 207 | simple method root ur phone instal triangle away apk run triangle away select reset counter ur phone restart select vol + for reset counter now ur phone restart ur problem slove. good luck |
