Old 03-05-2018, 10:20   #1 (permalink)
Member: 2325887
Thanks Meter: 134
Thumbs up after flash now imei null
FLASH INSTRUCTIONS:
1. Choose correct flash file(s).
2. If you have PIT file chosen, then you must check 'Repartition' option.
3. Check flashing options if needed (Repartition, EFS clear, Boot update).
4. Power on the phone in download mode (turn off phone, press vol.down + home + power).
5. Connect the phone to PC with USB cable, install drivers if needed.
6. Press 'Flash' button.
Operation: Flash
Selected model: SM-G935F
Software version: 30.8
File analysis... OK
Total file size: 0x10CA8E7DC (4298 Mb)
Searching USB Flash interface... COM8 detected
Setup connection... OK
Set PIT file... OK
Reading PIT from phone... OK
Sending sboot.bin... OK
Sending param.bin... OK
Sending cm.bin... OK
Sending boot.img... OK
Sending recovery.img... OK
Sending system.img... OK
Sending modem.bin... OK
Sending modem_debug.bin... OK
Sending cache.img... OK
Sending hidden.img... OK
Flashing done (time - 00:05:51)
Done with Samsung Tool PRO v.30.8
Old 03-05-2018, 11:03   #2 (permalink)
Member: 2325887
Thanks Meter: 134
baseband version unkonow
how to repair??????????????????
Old 03-05-2018, 12:28   #3 (permalink)
bhiret's Avatar
Member: 1295624
Thanks Meter: 152
Modem part damaged..try other firmware modems /write efs or nvm backup
Old 03-05-2018, 13:07   #4 (permalink)
Member: 2325887
Thanks Meter: 134
i have not efs and nvm
plz upload here
Old 03-05-2018, 14:05   #5 (permalink)
bhiret's Avatar
Member: 1295624
Thanks Meter: 152
!What was problem before flash?
Try other modems many posted on net also can flash modem part from 4 files rom package also can flash combination and check modem ok then backup efs and nv then flash original check if modem good then write nv ..make google search your assistant
Old 03-05-2018, 14:27   #6 (permalink)
Member: 2325887
Thanks Meter: 134
plz upload here laste version combination file
thanksssssssssssss
Page generated in 0.14322 seconds with 8 queries
