Old 11-07-2008, 16:21   #31 (permalink)
delchoni's Avatar
Member: 239176
Sonork: 100.1602815
Thanks Meter: 851
Sir sory for posted serial nomber ...
Originally Posted by blang View Post
don't post your card number in forums, cos this card was blocked for 1 week.
Card number + resseler name to me in pm.
sory for my post about serial nomber..........
Wbr.
Old 11-07-2008, 19:47   #32 (permalink)
Member: 79221
Thanks Meter: 8
z3x box problem! ! !
hello, I have a problem, I have a z3x box, my seller says my card is activate but I can make an update, I don't understand why!
the program windows is:
Card SN: 0005-....
Card FW: 1.3
User: No user with this SN
Activations:
in bottom right windows program there is write:
Card: 0005-...., FW:1.3, Box not found.
I don't understand.
Maybe Have done bad instal about :
2. Install Z3X-box Drivers from folder x:\Program Files\z3x\Box drivers\
3. Install Z3X-box Drivers from folder x:\Program Files\z3x\Card drivers\
I have open "setup _Wk2_xp.exe" in folder card drivers but it's all!
Please help me it's very emergency lot samsung are in waiting.
Sorry for my bad english
Thanks
Old 11-08-2008, 07:58   #33 (permalink)
delchoni's Avatar
Member: 239176
Sonork: 100.1602815
Thanks Meter: 851
im have the same problem...
Card SN: 0005-....
Card FW: 1.3
Activations:
I don't understand.
Thanks
im dont understend why activation is very very slow proces...!
br.
Old 11-10-2008, 16:40   #34 (permalink)
blang's Avatar
Member: 2368
Sonork: 100.111111
Thanks Meter: 186,557
br.
Send PM with SN and Resseler name. I will check your activation.
Old 11-12-2008, 10:12   #35 (permalink)
delchoni's Avatar
Member: 239176
Sonork: 100.1602815
Thanks Meter: 851
sir now all is ok .....
my box alerdy activated and im hapy ......
regards.
Old 11-25-2008, 11:05   #36 (permalink)
Member: 694888
New z3x box cant activate
Hi
Trying to activate my new z3x box.
All drivers installed.
The pc recognizas the box.
Shell starts Ok.
Apparently updating firmvare Ok.
But in step 2 of 4 when should activate the box gives error:
Here is what it says:
Card SN: 0005-****
Card FW: 1.3
User: halofon
Activations:
error message:
Access violation at address 006253FF in module 'z3x_shell.exe'. Read of address 0000000C.
Tryed on 3 diferent PCs. the same result......
Where the problem is?
Regards
Halofon
Old 11-25-2008, 11:13   #37 (permalink)
blang's Avatar
Member: 2368
Sonork: 100.111111
Originally Posted by [email protected] View Post
Hi
Shell starts Ok.
Card SN: 0005-****
Card FW: 1.3
User: halofon
Activations:
error message:
Regards
Halofon
You use windows XP?
In server side activation is done for your card.
Do you try run box software?
Try open box and clean card connector.
I have this problem with box first time.
I wait for results.
ATTENTION FOR ALL. IF YOU WILL SHARE CARD NUMBER IN FORUM. CARD will be stoped for 2 week.!!!
Old 11-25-2008, 12:15   #38 (permalink)
Member: 694888
Yes, I use Xp
I cant see if software works, because when Im trying to go support from Shell it tells: This function cant work with your card. first update your card.
Any other way to download software (if it is independent from shell - I ignore this detail...)
Regards
Halofon
Old 11-25-2008, 15:26   #39 (permalink)
Member: 694888
On my user web page I can see:
Card version v1.7 and its s/n 0005-*****
samsung tool v2.11 - activated
Cant download software from there (some other files can be downloaded)
I opened the box and not apparent contact problems in the card slot.
When the shell updates firmware, only from 0% to about 10% progress display can be seen... then it jumps directly to the next step, that ends up with error reported earler.
Help please....
regards
halofon
Old 11-25-2008, 21:56   #40 (permalink)
twentyonecell's Avatar
Member: 664744
Thanks Meter: 156
Card SN: xxxxxxxxx
Card FW: 1.3
Activations
please aktivation my card
thanks
Old 11-25-2008, 22:51   #41 (permalink)
blang's Avatar
Member: 2368
Sonork: 100.111111
Originally Posted by twentyonecell View Post
Card SN: xxxxxxxxx
Card FW: 1.3
Activations
thanks
Don't ask in forum about activaiton!!! Only resseler can make activation for you.
Old 11-25-2008, 23:38   #42 (permalink)
blang's Avatar
Member: 2368
Sonork: 100.111111
Help please....
regards
halofon
May be server busy, may be freez, anyway try later. this day server very busy.
For download software direct you can download from page www.z3x-box.com or login to support from page: www.z3x-team.com
Old 11-26-2008, 10:16   #43 (permalink)
Member: 39948
Thanks Meter: 68
Exclamation quetion about activate???
hi..
can i activate several smartcard with one user name and email ???
thanks.
Old 11-26-2008, 11:16   #44 (permalink)
blang's Avatar
Member: 2368
Sonork: 100.111111
Originally Posted by mentari View Post
hi..
thanks.
No. For 1 card only 1 email+login
The Following 2 Users Say Thank You to blang For This Useful Post:
Old 11-26-2008, 23:53   #45 (permalink)
Member: 694888
Trying to register on various PCs, on diferent hours even when server activitie was 0%.
Always the same error. I mean firmware actualization ends quickly (can see 0%, 2%, 4%, 6% sometimes 8% and it jumps to the message: Card firmware updated.
Then activation ends up with an error message. I have send dozens of this messages to you...
Software I downloaded from suggested page doesnt work either... the message is:
Product not activated on this card.
Any other suggestion?
By the way: shouldn´t the box be sent to customer already activated? I mentioned this kind of suggestions on some product and/or forum pages. Has the final user necesary administrator privilegies to perform activation?
Is it possible that card software is corrupted or hardware has same fault?
regards
halofon
The Following User Says Thank You to [email protected] For This Useful Post:
All z3x user read this wichielrico Z3X-Team Products 6 06-15-2011 15:02
Read this before using AERIX !!! sweunlockers Sony Ericsson 3 11-06-2009 08:50
fg box activated pack5 ... free one year access to support needed noure30 FuriousGold 6 08-01-2009 20:45
Voda 716 clip user read this befor use it paklink Vodafone Star 1 09-08-2008 15:56
All Original Prodigy Box User Read this.... MicrostarGSM® Federal One 0 07-08-2004 06:07
Page generated in 0.30581 seconds with 11 queries
